Durable 5739 SUPERCLEAN Foam Cleaner - 400ml
Quicklinx: 4FH8WS00 Mfr#: 5739
Effectively cleans plastic surfaces such as keyboards, mice, computer housings, printers and other office equipment. The antistatic, alcohol-free formulation also contains a long-lasting disinfectant.
  • Efficient cleaning
    Designed specifically for PCs, the DURABLE Superclean Foam offers an effective solution for maintaining your computer's cleanliness. Its formula is engineered to tackle dust, fingerprints, and everyday grime, ensuring your device remains in pristine condition.
  • Safe for use
    The DURABLE Superclean Foam is safe for all PC components, making it an ideal choice for users looking to preserve their hardware's integrity while keeping it clean. Its gentle formulation ensures that it can be used on a wide range of PC parts without causing damage.
DURABLE Superclean Foam - cleaning foam
Cleaning foam
White
Cleaning foam
White
