Drobo 8 Bay Dual iSCSI Storage Array
Quicklinx: 6N64WS00 Mfr#: DREL1A31
DroboElite offers the best data storage experience ever for small to medium businesses (SMBs) and departments looking to consolidate storage across multiple servers.
As the most powerful and flexible Drobo platform engineered to date, DroboElite redefines storage economics by delivering advanced features and performance usually reserved for more expensive solutions. Built on the BeyondRAID technology, DroboElite provides enterprise-level data safety and unprecedented expandability in a virtualized architecture that is both self-managing and self-healing. Dual iSCSI ports and significant performance enhancements deliver best-in-class performance ideal for consolidating storage or adding capacity to both virtualized and non-virtualized computing environments.
  • Multi-host connectivity
    Have multiple servers that need storage? No problem. The DroboElite connects seamlessly to your existing TCP/IP network and utilizes the industry-standard iSCSI protocol to provide simple, consolidated storage for your servers.
  • No headache dual-drive redundancy
    Enable the dual-drive redundancy option to protect against the simultaneous failure of up to two hard drives. It's all done with a single click, without ever losing access to your data. Running out of space? You can click to switch back to single drive redundancy. Unlike moving between traditional RAID 5 and RAID 6, there's no need to reformat or migrate data off of the array, potentially saving you hours or days of downtime.
  • Dual high-speed iSCSI interfaces
    Unfamiliar with iSCSI? It's an industry-standard, high performance protocol that has become extremely popular with businesses and individuals who demand high data storage throughput, but it can often be complex to manage. DroboElite changes that by introducing zero-click iSCSI connection creation with optional LUN-level CHAP authentication for both Windows and Mac OS X.
  • The virtues of Smart Volumes
    Create new volumes in seconds and manage up to 255 x 16TB volumes over time with ease. The time saving Smart Volume management technology integrated into DroboElite allows volumes to pull storage from the common pool of drives rather than a specific physical drive allocation, eliminating the need to manage capacity at the volume level. Smart Volumes are also data aware, allowing deleted data blocks to be returned to the common pool and ensuring that volumes remain as efficient as possible over time.
  • Simplify your VMware environment
    Storage is an integral part of a successful virtualization strategy. DroboElite has been tested for use with VMware to eliminate risk from your storage decision and help accelerate deployment of your virtual server environment.
  • Rack mount ready, desktop quiet
    DroboElite is equally at home in a rack mount environment as it is on your desktop. Dual smart fans automatically manage their speeds to optimize both cooling and minimize operating noise.
DroboElite - hard drive array
Hard drive array
Enclosure Type
3U
Max Supported Capacity
16 TB
iSCSI
Host Channels
2
8 (max)
Supported Drives
SATA-300
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
HDD
Linux, Microsoft Windows Server 2003, Apple MacOS X 10.5.6 or later, Microsoft Windows 7, Apple MacOS X Server 10.5.6 or later, Microsoft Windows Server 2008, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, VMware ESX Server 3.5, VMware ESXi 3.5
AC 120/230 V - 50/60 Hz
30.9 cm x 35.8 cm x 13.9 cm
7.3 kg
1-year warranty
Hard drive array
Enclosure Type
3U
Chassis
Supported Devices / Modules Qty
8
Supported Drives
SATA-300
Storage
16 TB
HDD Array External Interface
iSCSI
Host Channels
2
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Max Storage Devices Qty
8
Hard Drive
HDD
Expansion Bays
8 internal - 3.5" x 1/3H
1 x USB 2.0 (management) - 4 pin USB Type B , 2 x Ethernet 1000Base-T - RJ-45
1 x USB cable - 1.8 m , 2 x network cable - 1.8 m
Software Included
Drivers & Utilities, Drobo Dashboard
Rack Mounting Kit
Optional
Internal power supply
Power Provided
180 Watt
30.9 cm
35.8 cm
13.9 cm
7.3 kg
Limited warranty - 1 year
10 °C
35 °C
5 - 80%
Sound Emission
30.4 dB
