The latest generation 5 Bay NAS, the Drobo 5N2 delivers an unparalleled user experience for data sharing, secure backup, remote access and disaster recovery solutions. The 5N2 is the fastest, network attached Drobo available to prosumers and provides up to 2x performance boost with an upgraded processor and port bonding option. The 5N2 is built with Drobo's patented BeyondRAID technology to meet the demanding data storage requirements of connected home users, media professionals and small businesses. The expanded functionality includes technology features of Drobo's enterprise level products, such as DroboDR for disaster recovery backup.
Capacity and performance
Usually reserved for larger enterprise-class storage solutions, the Drobo 5N2 gives you the option to implement Hot Data Caching through the Drobo Accelerator Bay. This feature intelligently uses high-performance flash to accelerate performance, allowing the fastest possible access to your data. -
Dual Ethernet ports: bond together, or failover
The 5N2 has dual Gigabit Ethernet ports. These can be bonded together to provide approximately twice the read/write performance you get via a single port. Or they can be used to provide a connection to two different subnets. Furthermore, they can be used in an "active/passive" mode so that if one port fails the other takes over. -
Drobo disaster recovery
With DroboDR you can set up a pair of 5N2s to automatically make an offsite copy of your data. Simple to set up and manage, the reliable DroboDR seamlessly replicates your data to another 5N2 ensuring data availability in case of disaster. Even better, the remote 5N2 stores all user account information so recovery is painless. -
Power protecting your critical data
The Drobo 5N2 doesn't just protect from drive failures, it also includes a battery backup system that protects all data in memory or cache. That's right, Enterprise grade data protection for you on your Drobo 5N2! If power spontaneously goes away, the Drobo stays alive long enough for the data to be written to disk, ensuring your important information is always safe. The onboard battery recharges itself and is designed to last for the life of the product.
- Drobo 5N2 - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Storage Capacity Details
- Volume capacity: 64 TB
- Max Supported Capacity
- 50 TB
- Installed Devices / Modules Qty
- 0 (installed) / 5 (max)
- 15.03 cm x 26.23 cm x 18.54 cm
- 3.9 kg ()
- Storage Controller
- SATA SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.10 or later
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 50 TB
- 15.03 cm
- 26.23 cm
- 18.54 cm
- 3.9 kg ()
- Built-in Devices
- Led panel
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- SMB
- Network Services Compatibility
- Microsoft CIFS, Server Message Block (SMB), Apple File Protocol (AFP)
- Apple Time Machine compatible, failover protection, Jumbo Frames support (up to 9000 bytes), Adaptive Link Bonding, secure backup, remote data access and sharing, Disaster Recovery technology
- Expansion Bays
- 5 (total) / 5 (free) x hot-swap - 3.5" , 1 (total) / 1 (free) x internal - mSATA
- 2 x Ethernet 1000Base-T - RJ-45
- Cables Included
- 2 x network cable - 1.8 m
- Security lock slot (cable lock sold separately), BeyondRAID technology, built-in cooling fan, automatic fan speed control, backup battery, carrier-less drive bays, power fail protection
- Security Slot Type
- Kensington security slot
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 84 Watt - 7 A - 12 V
- Software Included
- Drivers & Utilities, Drobo Dashboard, DroboApps
- OS Required
- Limited warranty - 2 years
- 10 °C
- 35 °C
- 5 - 80%
- Sound Emission
- 30.4 dB
