DrayTek VigorSwitch VSG2280X-K Managed Gigabit Switch
Quicklinx: FCD5WS00 Mfr#: VSG2280X-K
£236.67 ex VAT
£284.00 inc VAT
VigorSwitch G2280x
10GbE Gigabit Switch with 24 Gigabit Ports & 4 10GbE SFP+ Uplink Ports
The VigorSwitch G2280x is a high-performance, L2+ Managed Gigabit Ethernet switch. With 24 1-Gigabit RJ-45 LAN ports and 4 10-Gigabit Ethernet SFP+ ports.
Use the 4 SFP+ ports for high speed uplinks between Switches, Servers and Network-Attached-Storage at up to 10 Gigabits per port.
Designed for centralised management, the VigorSwitch G2280x can be managed directly through its web interface, or provisioned and monitored through both the VigorACS management platform and/or, a DrayTek Vigor router’s Central Switch Management. Easily provision the VLAN configuration through the router and clone switch configurations. Drastically reduce the setup time required for a complex network, with VLANs spanning multiple switches.
10GbE SFP+ Ports for High Speed Uplinks
Advanced Layer 2+ Routing Features
Quiet Operation & Hardware Monitoring
Quality of Service & Bandwidth Control
Network Security and Management Features
ONVIF IP Camera Management
Central Management
Managing a VigorSwitch through VigorACS
Central Switch Management with a DrayTek Vigor Router
Energy Efficient Ethernet
Rack Mountable & Silent
IP Conflict Prevention
  • Auto surveillance & voice VLAN
    Recognize traffic from IP cameras and IP phones automatically and add CoS tag for QoS prioritization.
  • Web-based GUI
    Easily manage and monitor the network through the web-based console with graphics showing ports and hardware status.
  • IP conflict prevention
    Improve network stability by avoiding IP conflicts caused by a misconfigured or malicious host.
  • Central switch management
    Set up VLAN easily from the router and get a centralized hierarchy view of the switches.
Draytek VigorSwitch G2280X - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L2+ - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x 10/100/1000 + 4 x 10 Gigabit SFP+ (uplink)
Performance
Switching capacity: 128 Gbps , Buffer memory: 12 Mbit , Forwarding rate: 95.24 Mpps
Multicast groups: 256 , Total link aggregation groups: 8
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Routing Protocol
IGMPv2, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Flow control, auto-negotiation, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, IPv4 support, LLDP support, DHCP relay, Link Aggregation Control Protocol (LACP), DHCP client, Multicast VLAN Registration (MVR), loop prevention, port isolation, Class of Service (CoS), Strict Priority (SP), IP source guard, Link Aggregation, Voice VLAN, protected ports, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), DSCP based CoS, Q-in-Q tunnelling
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
44.1 cm x 27 cm x 4.5 cm
2.48 kg
United Kingdom
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Authentication Method
RADIUS, TACACS+, internal user database
24 x 1000Base-T RJ-45 , 4 x 10Gbit LAN SFP+ uplink , 1 x console RJ-45 management
Internal power supply
25 Watt
1 x console cable
Rack Mounting Kit
Included
RoHS
United Kingdom
44.1 cm
27 cm
4.5 cm
2.48 kg
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
