VigorSwitch G2280x
10GbE Gigabit Switch with 24 Gigabit Ports & 4 10GbE SFP+ Uplink Ports
The VigorSwitch G2280x is a high-performance, L2+ Managed Gigabit Ethernet switch. With 24 1-Gigabit RJ-45 LAN ports and 4 10-Gigabit Ethernet SFP+ ports.
Use the 4 SFP+ ports for high speed uplinks between Switches, Servers and Network-Attached-Storage at up to 10 Gigabits per port.
Designed for centralised management, the VigorSwitch G2280x can be managed directly through its web interface, or provisioned and monitored through both the VigorACS management platform and/or, a DrayTek Vigor router’s Central Switch Management. Easily provision the VLAN configuration through the router and clone switch configurations. Drastically reduce the setup time required for a complex network, with VLANs spanning multiple switches.
10GbE SFP+ Ports for High Speed Uplinks
Advanced Layer 2+ Routing Features
Quiet Operation & Hardware Monitoring
Quality of Service & Bandwidth Control
Network Security and Management Features
ONVIF IP Camera Management
Central Management
Managing a VigorSwitch through VigorACS
Central Switch Management with a DrayTek Vigor Router
Energy Efficient Ethernet
Rack Mountable & Silent
IP Conflict Prevention
Auto surveillance & voice VLAN
Recognize traffic from IP cameras and IP phones automatically and add CoS tag for QoS prioritization. -
Web-based GUI
Easily manage and monitor the network through the web-based console with graphics showing ports and hardware status. -
IP conflict prevention
Improve network stability by avoiding IP conflicts caused by a misconfigured or malicious host. -
Central switch management
Set up VLAN easily from the router and get a centralized hierarchy view of the switches.
- Draytek VigorSwitch G2280X - switch - 28 ports - Managed - rack-mountable
- Switch - 28 ports - L2+ - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x 10/100/1000 + 4 x 10 Gigabit SFP+ (uplink)
- Performance
- Switching capacity: 128 Gbps , Buffer memory: 12 Mbit , Forwarding rate: 95.24 Mpps
- Capacity
- Multicast groups: 256 , Total link aggregation groups: 8
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 12KB
- Routing Protocol
- IGMPv2, IGMPv3, MLDv2, MLD
- Remote Management Protocol
- SNMP 1, RMON, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
- Flow control, auto-negotiation, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, Broadcast Storm Control, IPv6 support, Multicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, IPv4 support, LLDP support, DHCP relay, LACP, DHCP client, MVR, loop prevention, port isolation, CoS, SP, IP source guard, Link Aggregation, Voice VLAN, protected ports, EEE, WRR, DSCP based CoS, Q-in-Q tunnelling
- IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
- Power
- AC 120/230 V (50/60 Hz)
- 44.1 cm x 27 cm x 4.5 cm
- 2.48 kg
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 16K entries
- 12KB
- Routing Protocol
- Authentication Method
- RADIUS, TACACS+, internal user database
- 24 x 1000Base-T RJ-45 , 4 x 10Gbit LAN SFP+ uplink , 1 x console RJ-45 management
- Power Device
- Internal power supply
- Voltage Required
- 25 Watt
- Cables Included
- 1 x console cable
- Rack Mounting Kit
- Included
- RoHS
- Localisation
- United Kingdom
- 44.1 cm
- 27 cm
- 4.5 cm
- 2.48 kg
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
