DrayTek VigorSwitch VP2280X-K Managed Gigabit Switch
Quicklinx: FCD4WS00 Mfr#: VSP2280X-K
Type: Gigabit Ethernet
Ports: 28
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
38 In Stock
£406.67 ex VAT
£488.00 inc VAT
Draytek VigorSwitch P2280X - Switch - Managed - 24 x 10/100/1000 (PoE+) + 4 x 10Gb Ethernet SFP+ - desktop, rack-mountable - PoE+ (400 W)
  • Auto surveillance & voice VLAN
    Recognize traffic from IP cameras and IP phones automatically and add CoS tag for QoS prioritization.
  • Web-based GUI
    Easily manage and monitor the network through the web-based console with graphics showing ports and hardware status.
  • IP conflict prevention
    Improve network stability by avoiding IP conflicts caused by a misconfigured or malicious host.
  • Central switch management
    Set up VLAN easily from the router and get a centralized hierarchy view of the switches.
Draytek VigorSwitch P2280X - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Power Over Ethernet (PoE)
PoE+
PoE Budget
400 W
Performance
Switching capacity: 128 Gbps , Forwarding rate: 95.24 Mpps , Packet buffer size: 12 Mbit
Link aggregation groups: 8 , ACL entries: 512 , VLANs supported: 255 , VLAN IDs: 4096
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Routing Protocol
VRRP, MSTP, RSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI, ICMP
Load balancing, VLAN support, DoS attack prevention, IPv6 support, SNTP support, sFlow, Virtual Route Redundancy Protocol (VRRP) support, event log, DHCP snooping, Quality of Service (QoS), Dynamic ARP Inspection (DAI), IPv4 support, LACP support, DHCP relay, DHCP client, Dynamic VLAN Support (GVRP), dual firmware images, Strict Priority Queuing (SPQ), Neighbor Discovery Protocol (NDP), loop prevention, port isolation, static routing, Virtual Stacking Management (VSM), Class of Service (CoS), ONVIF support, Duplicated Address Detection, Type of Service (ToS), DiffServ Code Point (DSCP) support, PoE circuit sorting protection, Storm Control, system log, IP source guard, rate limit, MAC address authentication, Authentication, Authorization and Accounting (AAA), DNS client, Voice VLAN, VLAN management, Guest VLAN, ingress rate limiting, Weighted Round Robin (WRR), MAC based VLAN, egress rate limiting, OpenVPN client
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1v, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
AC 120/230 V
44.1 cm x 27 cm x 4.5 cm
4.32 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
400 W
Performance
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
Status Indicators
Port transmission speed, power, alert, system, PoE, link/activity
24 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x Gigabit / 10Gbit LAN SFP , 1 x console RJ-45
Internal power supply
AC 120/230 V
480 Watt
Rack Mounting Kit
Included
RoHS
44.1 cm
27 cm
4.5 cm
4.32 kg
45 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Ports: 28
Managed: Yes
POE: PoE+
Brand: DrayTek
