DrayTek VigorSwitch P2500 50-Port PoE+ Gigabit Switch
Quicklinx: F9QLWS00 Mfr#: VSP2500-K
DrayTek VigorSwitch P2500 is a Layer 2 Managed Gigabit PoE switch. It has 44x Gigabit Ethernet PoE/PoE+ ports with a power budget of 405 watts. Perfect for a business network with many PoE devices. It also has 4x GbE/SFP combo ports, 2x SFP ports, 1x console port, and enterprise-level features to help businesses to improve network security and stability.
  • PoE (Power over Ethernet)
    Deliver power and data over one Ethernet cable, turn on/off the PoE device periodically with PoE Schedule.
  • PoE device check
    Enable Ping Watchdog for all PoE devices, if they lose their network connection, automatically restart them by a power cycle.
  • Auto surveillance & voice VLAN
    Recognize traffic from IP cameras and IP phones automatically and add CoS tag for QoS prioritization.
  • IP conflict prevention
    Improve network stability by avoiding IP conflicts caused by a misconfigured or malicious host. Learn more
  • Access control
    VigorSwitch P2500 supports ACL by IP/MAC and 802.1x port access control with RADIUS to filter unauthorized hosts.
  • ONVIF-friendly
    Recognize the ONVIF devices, display surveillance topology, provide UI for video streaming and device maintenance.
  • QoS (Quality of Service)
    Improve the performance of critical traffic by prioritizing the traffic with CoS, DSCP, and IP Precedence tag.
  • IPv6 ready
    VigorSwitch P2500 supports IPv6 by offering MLD Snooping, IPv6 ACL, and IPv6 DNS Resolver.
  • Multiple Admin accounts
    Multiple Admin accounts with two levels of administrator privilege.
  • Central switch management
    Set up VLAN easily from the router and get a centralized hierarchy view of the switches. Learn more
  • Energy-efficient Ethernet
    Compliant with IEEE 802.3az to reduce power consumption.
Draytek VigorSwitch P2500 - switch - 50 ports - Managed - rack-mountable
Switch - 50 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
44 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP + 2 x SFP
Power Over Ethernet (PoE)
PoE+
Performance
Switching capacity: 56 Gbps , Forwarding rate: 41.7 Mpps , Packet buffer size: 12 Mbit
Multicast groups: 256 , Total link aggregation groups: 16 , Links per group: 8 , ACL entries: 512
MAC Address Table Size
16K entries
Jumbo Frame Support
12KB
Routing Protocol
IGMPv2, IGMPv3, MLDv2, MLD, MSTP, STP
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI, TR-069, RSTP
Flow control, DHCP support, auto-negotiation, trunking, load balancing, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, DiffServ support, Broadcast Storm Control, IPv6 support, Multicast Storm Control, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, RADIUS support, SSH support, MLD snooping, reset button, IPv4 support, fanless, LACP support, LLDP support, LACP, Traffic Control, port based access control, MVR, Multicast filtering function, CoS, SP, DSCP support, Protocol-based VLANs support, IP source guard, ARP inspection, Voice VLAN, VLAN management, LLDP-MED, Guest VLAN, protected ports, EEE, WRR, VLAN Tagging, port-based VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az, IEEE 802.3q, IEEE 802.1az
44.1 cm x 27 cm x 4.5 cm
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
Performance
16K entries
Jumbo Frame Support
12KB
Routing Protocol
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
Status Indicators
Port transmission speed, power, system, link/activity
44 x 1000Base-T RJ-45 , 4 x Gigabit LAN RJ-45/SFP , 1 x console RJ-45 management , 2 x Gigabit LAN SFP
Internal power supply
Rack Mounting Kit
Included
44.1 cm
27 cm
4.5 cm
45 °C
10 - 90% (non-condensing)
