DrayTek VigorSwitch P2100 8+2 Port Switch with PoE+
Quicklinx: G7V9WS00 Mfr#: VSP2100-K
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: Yes
POE: PoE+
Hurry, only 3 left in stock!
£161.11 ex VAT
£193.33 inc VAT
DrayTek VigorSwitch P2100 is a compact Layer 2+ Managed Gigabit PoE switch well-suited for smart home and branch/remote sites. It has 2x GbE SFP ports, 8x Gigabit Ethernet PoE/PoE+ ports with power budget of 140 watts, and 1x console port. Featuring Layer 3 features, including DHCP Server and VLAN Routing, VigorSwitch P2100 improves local network sustainability and efficiency regardless of the gateway. Furthermore, with IP Conflict Detection & Prevention, ONVIF Surveillance, ping watchdog and a lot more, this is the balanced switch that brings advanced features into small environments.
  • PoE (Power over Ethernet)
    Deliver power and data over one ethernet cable, turn on/off the PoE device periodically with PoE Schedule.
  • PoE device check
    Enable Ping Watchdog for all PoE devices, if they lose their network connection, automatically restart them by a power cycle.
  • Auto surveillance & Voice VLAN
    Recognize traffic from IP cameras and IP phones automatically and add CoS tag for QoS prioritization.
  • ONVIF-friendly
    Recognize the ONVIF devices, display surveillance topology, provide UI for video streaming and device maintenance. Learn more
  • Wire-speed VLAN routing
    Improve overall network performance by using VigorSwitch P2100 to route the inter-VLAN traffic directly and offload the router.
  • IP Conflict Prevention
    Improve network stability by avoiding IP conflicts caused by a misconfigured or malicious host.
  • Access Control
    VigorSwitch P2100 supports ACL by IP/MAC and 802.1x port access control with RADIUS to filter unauthorized hosts.
  • QoS (Quality of Service)
    Improve the performance of critical traffic by prioritizing the traffic with CoS, DSCP, and IP Precedence tag.
  • IPv6 Ready
    VigorSwitch P2100 supports IPv6 by offering MLD Snooping, IPv6 ACL, and IPv6 DNS Resolver.
  • Web-based GUI
    Easily manage and monitor the network through the web-based console with graphics showing ports and hardware status. See demo
  • Multiple Admin accounts
    Multiple Admin accounts with two levels of administrator privilege.
  • Central switch management
    Set up VLAN easily from the router and get a centralized hierarchy view of the switches. Learn more
  • Energy-efficient Ethernet
    Compliant with IEEE 802.3az to reduce power consumption.
Draytek VigorSwitch P2100 - switch - 8 ports - Managed - rack-mountable
Switch - 8 ports - L2+ - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP (uplink)
Power Over Ethernet (PoE)
PoE+
PoE Budget
140 W
Performance
Forwarding performance (64-byte packet size): 14.88 Mpps , Switching capacity: 20 Gbps
Virtual interfaces (VLANs): 256 , QoS queues: 8 , Total link aggregation groups: 4
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, static IP routing, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2
Flow control, auto-negotiation, load balancing, VLAN support, IGMP snooping, Syslog support, traffic shaping, E-mail alert, WRR queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, SNTP support, STP support, RSTP support, MSTP support, DHCP snooping, ACL support, QoS, DHCP server, MLD snooping, DAI, reset button, IPv4 support, LLDP support, Energy Efficient Ethernet, MVR, SPQ, port isolation, CoS, tagged VLAN, GVRP, ONVIF support, DSCP support, Protocol-based VLANs support, IP source guard, layer 2+ switching, Link Aggregation, scheduler, rate limit, AAA, IGMP querier, VLAN Double Tagging (Q-in-Q), Voice VLAN, VLAN management, LLDP-MED, Private MIB, Guest VLAN, DoS protection, DSCP based CoS, MAC based VLAN, loopback detection, Unknown Storm Control, 4.1Mbit packet buffer, Address Conflict Detection, OpenVPN client, DSCP based QoS
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
AC 120/230 V
31.9 cm x 20.8 cm x 4.5 cm
2.61 kg
United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
140 W
Performance
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Authentication Method
RADIUS, TACACS+, Secure Shell v.2 (SSH2), internal user database
8 x 1000Base-T RJ-45 PoE+ , 2 x Gigabit LAN SFP , 1 x console RJ-45 management
Internal power supply
AC 120/230 V
164.3 Watt
1 x console cable
Rack Mounting Kit
Included
FCC
United Kingdom
31.9 cm
20.8 cm
4.5 cm
2.61 kg
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 8
Managed: Yes
POE: PoE+
Brand: DrayTek
