DrayTek VigorSwitch G1080 Web Smart Gigabit Switch
Quicklinx: DNLFWS00 Mfr#: VSG1080-K
Type: Gigabit Ethernet
Ports: 8
Data Transfer Rate: [N/A]
Managed: Yes
POE: No
Hurry, only 2 left in stock!
£49.41 ex VAT
£59.29 inc VAT
The VigorSwitch G1080 is ideal for SOHO and small business with the high-performance capability. To cater for high bandwidth traffic, it is equipped with 8 Gigabit Ethernet ports. VigorSwitch G1080 is equipped with extensive facilities for maximizing your LAN performance, VLAN capability to allow flexible network configuration and QoS capability for flexible bandwidth control.
  • LAN Management
    VigorSwitch G1080 offers features that can build a secure business network, such as VLAN, Storm Control. While someone tries to connect to the network for Internet access, these features help to block the access to the business network resources and protect the network from being exhausted by malicious traffic.
  • Speed up the network by Link Aggregation
    If cascading more switches are required, link aggregation will provide the network higher throughput and link redundancy. VigorSwitch G1080 supports link aggregation by LACP (Link Aggregation Control Protocol), 1 Link Aggregation Group can be set up on VigorSwitch G1080, and the group can have up to 2 port members.
  • Power-saving
    The VigorSwitch G1080 helps you build a green networking by offering power-saving features, such as IEEE 802.3az (Energy-Efficient Ethernet), which allows the switch to dynamically adjust the power on each port according to the client activity and cable length, this can be an ideal power saving solution for your company.
Draytek VigorSwitch G1080 - switch - 8 ports - Managed
Switch - 8 ports - Managed
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Virtual interfaces (VLANs): 8
MAC Address Table Size
4K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2
VLAN support, IGMP snooping, Broadcast Storm Control, Multicast Storm Control, Unicast Storm Control, firmware upgradable, WFQ, QoS, reset button, IPv4 support, Energy Efficient Ethernet
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3ad (LACP), IEEE 802.3az
15.5 cm x 8.5 cm x 2.6 cm
2.6 kg
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
4K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2
Status Indicators
Link/activity
8 x 1000Base-T RJ-45
External power adapter
15.5 cm
8.5 cm
2.6 cm
2.6 kg
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 8
Managed: Yes
POE: No
Brand: DrayTek
