DrayTek VigorAP 960C Access Point
Quicklinx: G9LPWS00 Mfr#: VAP960C-K
  • IEEE 802.11n
£184.44 ex VAT
£221.32 inc VAT
The DrayTek VigorAP 960C is a Wi-Fi 6 AX1800 access point. The new wireless standard does more than simply boost speeds for single users, it improves overall performance for busy environments. More efficient resource sharing results in greater overall performance, lower latency and less pauses in connectivity for users.
To achieve this, Wi-Fi 6 or 802.11ax brings in several new technologies (including some features used extensively by 4G and LTE networks), to enhance speeds even as many users demand content at the same time. As more devices need bandwidth more frequently, Wi-Fi 6 utilises key technologies to enable this.
Wi-Fi 6 - Fast & Efficient
Higher Capacity with OFDMA and Multi-User MIMO
Less Interference with BSS Colouring
Dual-Band Performance Boost with 2.4GHz and 5GHz Wi-Fi 6
Better Battery Life on Mobile Devices with Target Wake Time
Mesh Wireless
Mesh - Auto-Optimising & Self-Healing
Multi-SSID over Mesh
Gigabit Power-over-Ethernet
Easy Setup with the DrayTek Wireless app
Ceiling or Wall Mounted
AP & Repeater Modes
Cloud Management - VigorACS
Router-based Central Management
VigorAP-based Central Management
VigorConnect - Central Management Server
Draytek VigorAP 960C - radio access point - Wi-Fi 6
Radio access point
Wall / ceiling mountable
United Kingdom, Ireland
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
Wireless clients: 256 , SSIDs total: 8
Cover, mounting kit
Power Over Ethernet (PoE) Supported
PoE
17.8 cm x 17.8 cm x 3.5 cm
380 g
Radio access point
17.8 cm
17.8 cm
3.5 cm
380 g
Wireless
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI, TR-069
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX1800
VLAN support, DFS support, firmware upgradable, Mesh networking, Wi-Fi Multimedia (WMM) support, DHCP server, DHCP relay, system log, band steering, VLAN management, Fast Roaming, PMK Caching, Airtime Fairness, client isolation, interference detection function, flow monitoring, MAC clone, schedule reboot, Multi-User MIMO & Beamforming technology, Orthogonal Frequency Division Multiple Access (OFDMA), self-healing network, Wireless Auto On/Off, Device Object/Group Control, Wi-Fi 6 technology, BSS Coloring, TCP support, PiFA Dual-Band Antennas
Encryption Algorithm
PEAP, WPA, WPA2-Enterprise, WPA3-Enterprise, WPA3-Personal, WPA2-Personal, EAP-TLS
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.1Q, IEEE 802.3af, IEEE 802.1x, IEEE 802.11r
Aerial
Antenna
Internal
Antenna Qty
2
1 x 1000Base-T (PoE) - RJ-45
Cover, mounting kit
1 x network cable
PoE
Power injector
11 Watt
10 - 90% (non-condensing)
Type: Radio access point
Connectivity: Wireless
Speed: 1200Mbps
Protocol: IEEE 802.11n
Protocol: IEEE 802.11b
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac Wave 2
Protocol: 802.11ax
Antennas: 2
Brand: DrayTek
