DrayTek VigorAP 920R Series outdoor access point is designed to meet the requirement of wireless network connection in rugged and hazardous locations. VigorAP 920R is provided with waterproof feature and is made from industrial-grade components. With the durable and weatherproof case, it is suitable for harsh physical environments including wind, rain and snow; and simultaneously it offers various functions to establish seamless, reliable, secure Wi-Fi network with high performance.
- Draytek VigorAP 920R - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom, Ireland
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- Localisation
- Form Factor
- External
- Connectivity Technology
- Wireless
- Frequency Band
- 2.4 GHz, 5 GHz
- Repeating mode, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, RADIUS support, Wi-Fi Protected Setup (WPS), Multiple SSID support, hidden SSID, temperature / humidity sensor, wireless bridge mode, reset button
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, TLS, PEAP, TKIP, WPA-PSK, WPA2-PSK
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.3az, IEEE 802.11ac
Aerial
- Antenna
- External detachable
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45 , 2 x aerial - N connector
- IP67
- -40 °C
- 70 °C
- 5 - 95% (non-condensing)
