VigorSwitch P1280 is designed for SOHO and small business network that runs various network applications. The PoE+ Ethernet ports are perfect for a network with wireless AP, IP phones, and IP surveillance. VigorSwitch P1280 meets the IEEE 802.3az standard to reduce power consumption and lower the electricity bill, the auto Voice VLAN and QoS feature help to improve the VoIP call quality on the network.
LAN security
VigorSwitch P1280 offers features that help to build a secure business network, such as VLAN, port isolation, storm control, and DoS defense. While allowing visitors to connect to the network for Internet access, these features help to block the visitors' access to business network resources and protect the network from being exhausted by malicious traffic. -
Voice VLAN to improve call quality
The Voice VLAN feature allows VigorSwitch P1280 to automatically identify the traffic from a VoIP device and assign their source port to a separate VLAN. This allows the switch to efficiently give VoIP traffic a higher priority over others, thus to ensure high call quality. -
PoE+ for cost-saving and flexible installation
All the Ethernet ports of VigorSwitch P1280 are compatible with 802.3at and 802.3af standard. This reduces the need for power cables and adapters, which lowers the cost of installation, as well as offers the flexibility to install those devices, not being limited by where the power outlets are.
- Draytek VigorSwitch P1280 - switch - 24 ports - smart - rack-mountable
- Switch - 24 ports - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 24 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 340 W
- Capacity
- Virtual interfaces (VLANs): 4096
- MAC Address Table Size
- 8K entries
- Jumbo Frame Support
- 9KB
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069
- Flow control, auto-negotiation, load balancing, VLAN support, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, event log, Quality of Service (QoS), reset button, IPv4 support, Strict Priority Queuing (SPQ), port isolation, Class of Service (CoS), tagged VLAN, DiffServ Code Point (DSCP) support, Storm Control, cable test, Energy-Efficient Ethernet (EEE), DSCP based CoS
- IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
- Power
- AC 230V
- 44.1 cm x 27 cm x 4.5 cm
- 4.35 kg
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop, rack-mountable, wall-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE+
- PoE Budget
- 340 W
- Capacity
- 8K entries
- 9KB
- Status Indicators
- Power, system, PoE
- 24 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x Gigabit LAN SFP , 4 x 1000Base-T RJ-45
- Power Device
- Internal power supply
- Voltage Required
- AC 230V
- 453.3 Watt
- Rack Mounting Kit
- Included
- RoHS
- Localisation
- United Kingdom
- 44.1 cm
- 27 cm
- 4.5 cm
- 4.35 kg
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
