DrayTek Vigor AP-912C Ceiling/Wall WiFi AP
Quicklinx: FNF9WS00 Mfr#: VAP912C-K
Type: Radio access point
Connectivity: Wireless
Speed: 866Mbps
Protocol: IEEE 802.11a, IEEE 802.11ac Wave 2, IEEE 802.11b, IEEE 802.11n + 1 more
Compatibility: [N/A]
  • IEEE 802.11n
17 In Stock
£80.00 ex VAT
£96.00 inc VAT
Mesh Wireless
Link up to eight (8) DrayTek VigorAP access points (additional units sold separately) over wireless with Mesh. Mesh auto configures wireless links.
Easy to configure and manage
Setup of the VigorAP 912C is easy with the DrayTek Wireless app.
Dual-Band 11ac (WiFi 5) Wave 2 Access Point
Up to 866Mbps + 300Mbps total wireless bandwidth. Connect 128 clients per wireless band, 256 in total.
Wireless security & VLANs
Secure your wireless networks with 802.1x and Access Control.
AP & Repeater modes
Use the VigorAP 912C as an Access Point or extend an existing wireless network.
Central management with VigorACS
Manage VigorAPs from the cloud with DrayTek VigorACS (sold separately).
Ceiling mounting
With the flexibility in mind, the VigorAP 912C is designed to be installed on ceilings and walls.
  • Mesh
    Easily link to other VigorAP to expand the wireless network.
  • PoE power supply
    Simplify the infrastructure by getting data and power through a single cable.
  • Airtime fairness
    Equalize the transmission time of each client so the legacy devices won't slow everyone down.
  • Band steering
    Redirect 5GHz-capable devices to the 5GHz radio to get a faster speed.
  • Assisted Wi-Fi roaming
    Solve the sticky client problem and improve Wi-Fi roaming experience.
  • Wi-Fi scheduling
    Schedule Wi-Fi On and Off to control wireless access and save energy.
  • Central AP management
    Manage, maintain, and monitor VigorAP 912C from the DrayTek routers.
Draytek VigorAP 912C - radio access point - Wi-Fi 5
Radio access point
In-ceiling
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum data rate (2.4 GHz): 300 Mbps , Maximum data rate (5 GHz): 866 Mbps
Ceiling mounting kit, T-Rail mounting kit
Power Over Ethernet (PoE) Supported
PoE
AC 100 - 240 V
16.2 cm x 16.2 cm x 4.2 cm
300 g
Radio access point
16.2 cm
16.2 cm
4.2 cm
300 g
In-ceiling
Wireless
Data Transfer Rate
866 Mbps
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, CLI, TR-069
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AC1200
Power over Ethernet (PoE), repeating mode, Syslog support, MAC address filtering, Wireless Distribution System (WDS) support, firmware upgradable, wall mountable, Mesh networking, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), RADIUS support, Wi-Fi Protected Setup (WPS), Multiple SSID support, hidden SSID, reset button, 2T2R MIMO technology, DHCP client, tagged VLAN, band steering, Airtime Fairness, Multi-User MIMO & Beamforming technology, AP-Assisted Roaming, Wireless Auto On/Off, Multi-SSID over Mesh, Client Limit per SSID, Trusted DHCP Server IP for WLAN, Device Object/Group Control
Encryption Algorithm
TLS, PEAP, WPA2, WPA2-PSK, WEP, WPA3
Authentication Method
RADIUS, Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
1 x 1000Base-T (PoE) - RJ-45
1 x network cable
PoE
External power adapter
AC 100 - 240 V
10 Watt
45 °C
10 - 90% (non-condensing)
Speed: 866Mbps
Protocol: IEEE 802.11ac Wave 2
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: IEEE 802.11g
Antennas: [N/A]
Brand: DrayTek
