DrayTek Vigor 3910 Multi-WAN router
Quicklinx: FN12WS00 Mfr#: V3910-K
Type: Router
Connection Type: WAN/LAN
Standards: Gigabit Ethernet, PPP, Fast Ethernet, Ethernet + 2 more
Speed: 900Mbps
Rackmount or External: Rack-mountable
£651.61 ex VAT
£781.93 inc VAT
The DrayTek Vigor 3910 is a multi-WAN router and an ideal VPN concentrator, delivering high performance to meet the current and future bandwidth demands of complex networks. The Vigor 3910 combines performance, capacity and flexibility, with ease of use and a comprehensive feature set.
  • Powerful enterprise Internet gateway
    Featuring a quad-core processor, the Vigor 3910 readily meets the needs of demanding networks, with over 9Gb/s NAT throughput delivered through its 10GbE and 2.5GbE ports.
  • High-performance VPN concentrator
    Protect inter-office communication with securely encrypted Virtual Private Network tunnels, maintaining 3 Gb/s IPsec throughput and supporting 500 simultaneous VPN links.
  • Flexible WAN architecture
    Spread the load across up to 8 WAN links with Load Balancing. Policy-based Routing enables intelligent and flexible failover, for reliable and resilient connectivity.
  • High availability
    Provide hardware redundancy to mission critical applications with the installation of a second Vigor 3910. The backup autonomously resumes connections in the event of hardware failover.
  • Manage multiple networks
    Create up to 50 VLANs, port-based or tag-based. Each fully configurable for NAT or Routing, sharing resources between networks or isolated from each other.
Draytek Vigor 3910 - router - rack-mountable
Router
Enclosure Type
Rack-mountable - 1U
WAN Ports Qty
8
Ethernet, Fast Ethernet, Gigabit Ethernet, 10 Gigabit Ethernet, 2.5 Gigabit Ethernet, PPP
Performance
NAT throughput: 9 Gbps , VPN throughput (IPSec): 3.3 Gbps , VPN throughput (SSL): 1 Gbps
Concurrent VPN tunnels: 500 , Virtual interfaces (VLANs): 50 , NAT sessions: 150000 , Dynamic IP pool: 4093 , Concurrent SSL VPN tunnels: 200
Network / Transport Protocol
IPSec, IPv6, DNS, DDNS, IPv4, DHCP, PPPoE, Bonjour, SMB, PPTP, L2TP, RTSP, DHCPv6, FTP
Routing Protocol
Static IP routing, static IPv4 routing, static IPv6 routing, RIP-1, RIP-2, RIPng, BGP, OSPFv2, policy-based routing (PBR), GRE, IGMP
Remote Management Protocol
HTTP, HTTPS, SSH, Telnet, TR-069, TFTP, SNMP 1, SNMP 2c, SNMP 3
VoIP Protocols
H.323, SIP
Load balancing, High Availability, VPN support, firewall protection, failover protection, IPv6 support, IP address filtering, content filtering, QoS, DSCP support, VLAN support, IPv4 support, reset button, DynDNS, VPN concentrator, VLAN Tagging, port-based VLAN, DHCP server, IP-MAC binding, DNS server, port mirroring, IGMP proxy, file sharing, IPSec NAT-T, port triggering, DMZ support, ALGs, URL filtering, DoS attack prevention, anti-spoofing protection, ToS, firmware upgradable, ACL support, Brute Force Protection, Syslog support, SMS alert, E-mail alert, Bandwidth Limiter, Data prioritization (Qos) for VoIP applications, ALG support, NAT support, Web Filtering
IEEE 802.1p, IEEE 802.1Q, UPnP, X.509
AC 230V
44.3 cm x 28.5 cm x 4.5 cm
3.23 kg
United Kingdom, Ireland
Router
Enclosure Type
Rack-mountable - 1U
Wired
Performance
Routing Protocol
Encryption Algorithm
SSL, IKEv2, SHA-1, 256-bit SHA, MD5, DES, Triple DES, MPPE, AES
Authentication Method
RADIUS, XAUTH authentication, X.509 certificates, LDAP, TACACS+, internal user database
1.2 GHz
Built-in Devices
Led panel
IP Telephony
VoIP Protocols
H.323, SIP
WAN / LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 2 x 2.5GBase-T - RJ-45 , WAN / LAN: 2 x 10Gb Ethernet / 1Gb Ethernet - SFP+ , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , Management: 1 x RS-232 - RJ-45
Internal power supply
AC 230V
35 Watt
1 x network cable , 1 x serial cable
Rack Mounting Kit
Included
OS Provided
DrayOS
44.3 cm
28.5 cm
4.5 cm
3.23 kg
Limited warranty - 2 years - carry-in
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: PPP
Standards: Fast Ethernet
Standards: Ethernet
Standards: 2.5 Gigabit Ethernet
Standards: 10 Gigabit Ethernet
Speed: 900Mbps
Brand: DrayTek
Price Range Ex VAT: £500 - £750
