DrayTek Vigor 2962 Dual-WAN Firewall Router
Quicklinx: G4XPWS00 Mfr#: V2962-K
Type: Router
Connection Type: WAN/LAN
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet
Speed: 900Mbps
Rackmount or External: Rack-mountable
16 In Stock
£397.85 ex VAT
£477.42 inc VAT
The DrayTek Vigor 2962 Dual-WAN Load Balancing Firewall VPN router surpasses Gigabit speeds, to get the best performance out of FTTP Fibre Broadband and more. Connects to 2.5Gb Ethernet and SFP Fibre, for LAN or WAN use.
The Vigor 2962 provides a reliable, flexible, and secure network solution with extensive Firewall, Content Filtering, VPN client/server and Quality of Service controls.
An ideal VPN concentrator with 500Mbps SSL VPN performance. Connect up to 50 SSL VPN & OpenVPN users, or 200 IPsec tunnels, simultaneously. With up to 20 LAN subnets, BGP and OSPF, it’s well equipped to manage larger, more complex networks and Multi Occupancy Offices.
2.5 Gigabit, Ethernet & SFP Dual WAN Load Balancer
Route Policy - Powerful Routing Management
Flexible LAN/WAN Ports
Ideal VPN router for SMB
Connecting Remote Sites with LAN to LAN VPN
Connect VPNs from behind NAT with DrayTek's VPN Matcher
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
Manage Multiple Networks
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
Web Content Filtering with DNS Filter
DrayDDNS - DrayTek Dynamic DNS Address
High Availability - Hardware Failover
Manage Guest WiFi with Hotspot Web Portal
Quality of Service & Bandwidth Control
Central AP & Switch Management
  • Load balancing
    Maximize throughput and reliability by using multiple Internet connections.
  • VPN (Virtual Private Network)
    Build a secure and private tunnel from the LAN of Vigor2926 Series to the remote offices and teleworkers over the Internet.
  • SSL VPN
    The VPN works through firewalls providing secure remote access to any network environment.
  • VPN Matcher
    Helps routers behind NAT to find each other and establish a LAN-to-LAN VPN.
  • Firewall and Content Filter
    Filter web pages by URL keyword or web category to block access to insecure or inappropriate contents.
  • VoIP Friendly
    Vigor2926 Series can do port forwarding and reserve bandwidth for VoIP traffic automatically, making VoIP setup effortless.
  • Bandwidth Management
    Prevent one device using all the bandwidth by bandwidth limit policy, session limit policy, and QoS settings.
  • Hotspot Web Portal
    Market your business and communicate with the guests while offering hospitality Wi-Fi.
  • Wireless WAN (Wireless model only)
    Get Internet access wirelessly from a Wi-Fi network, a mobile hotspot, or a personal hotspot set up on smartphones.
  • DrayDDNS
    The DDNS service for you to access the router by a fixed hostname of your choice.
  • Mesh
    Easily link to other VigorAP to expand the wireless network.
  • Central AP management
    Use the Vigor2926 Series router as a wireless controller to maintain and monitor the VigorAPs.
  • Central switch management
    Set up VLAN easily from the router and get a centralized hierarchy view of the switches.
Draytek Vigor 2962 - router - desktop, rack-mountable
Router - 4-port switch (integrated)
Enclosure Type
Desktop, rack-mountable
Digital Signaling Protocol
SIP, H.323
WAN Ports Qty
2
Performance
NAT throughput with hardware acceleration: 2.2 Gbps , VPN throughput (256-bit AES IPSec): 900 Mbps , VPN throughput (SSL): 650 Mbps
Concurrent VPN tunnels: 200 , NAT sessions: 300000 , Concurrent SSL VPN tunnels: 200 , 802.1q virtual interfaces (VLANs): 50
Network / Transport Protocol
PPPoE, DHCP, DHCPv6, ARP, DNS, DDNS, Bonjour, PPTP, L2TP, IPSec, RTSP, FTP
Routing Protocol
GRE, BGP, OSPF, RIP-1, RIP-2, RIPng
Remote Management Protocol
HTTP, HTTPS, Telnet, SSH-2, TR-069, TFTP, SNMP 1, SNMP 2c, SNMP 3
VoIP Protocols
SIP, H.323
IPv6 support, IPv4 support, PPP, multiple PVC support, load balancing, broadcast threshold, port-based VLAN, tagged VLAN, DHCP server, IP-MAC binding, 802.1x authentication, port mirroring, DNS server, PIN code authentication, High Availability, DNSSEC support, IGMP proxy, LAN-to-LAN bridging, L2TP over IPSec, OTP, IPSec NAT-T, NAT support, DMZ support, port triggering, ALG support, VPN passthrough, application filtering, DNS filtering, URL filtering, Web Filtering, anti-spoofing protection, DoS protection, bandwidth control, Bandwidth Limiter, QoS, ToS, DSCP based QoS, QoS for VOIP, firmware upgradable, ACL support, Brute Force Protection, E-mail alert, SMS alert, Syslog support
IEEE 802.1p, IEEE 802.1Q, IEEE 802.1x
AC 120/230 V
27.3 cm x 17.1 cm x 4.5 cm
1.3 kg
United Kingdom, Ireland
Enclosure Type
Wired
Performance
Routing Protocol
Encryption Algorithm
SSL, IKEv2, SHA-1, SHA-256, MD5, MPPE, DES, Triple DES, AES
Authentication Method
RADIUS, XAUTH authentication, LDAP, TACACS+, X.509 certificates
Status Indicators
Active, SFP, USB
Communications
SIP, H.323
IP Telephony
VoIP Protocols
SIP, H.323
WAN / LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 2.5GBase-T , WAN / LAN: 1 x 1000Base-X - RJ-45/SFP , USB 2.0: 1 x , USB 3.0: 1 x
Internal power supply
AC 120/230 V
15 watt
Rack Mounting Kit
Included
27.3 cm
17.1 cm
4.5 cm
1.3 kg
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: 2.5 Gigabit Ethernet
Speed: 900Mbps
Brand: DrayTek
