DrayTek Vigor 2927LAC LTE WiFi Router
Quicklinx: G4XNWS00 Mfr#: V2927LAC-K
Type: Wireless router
Connection Type: WAN/LAN
Standards: Fast Ethernet, IEEE 802.11g, IEEE 802.11n, Ethernet + 5 more
Speed: 300Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
Hurry, only 1 left in stock!
£395.70 ex VAT
£474.84 inc VAT
The DrayTek Vigor 2927Lac is a powerful Dual-WAN, Load Balancing, Firewall & VPN Router. It comes packed with features, allowing you to make the most of FTTP Fibre Broadband, with Gigabit WAN throughput, extensive Firewall, Content Filtering, VPN client/server, and Quality of Service controls.
It incorporates an integrated 4G/LTE modem so you can take advantage of mobile broadband, and with fast Dual-Band AC1300 WiFi the Vigor 2927Lac provides a reliable, flexible, and secure network solution that’s ideal for Small Business and Home Offices.
Dual Gigabit WAN Load Balancer
Route Policy - Powerful Routing Management
Integrated LTE 4G/3G Modem
Constant Connectivity - Dual-SIM LTE
Wireless LAN
Ideal VPN router for SMB
Connect VPNs from behind NAT with DrayTek's VPN Matcher
Connecting Remote Sites with LAN to LAN VPN
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
5+1 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
Web Content Filtering with DNS Filter
DrayDDNS - DrayTek Dynamic DNS Address
High Availability - Hardware Failover
Manage Guest WiFi with Hotspot Web Portal
Quality of Service & Bandwidth Control
Central AP & Switch Management
Draytek Vigor 2927LAC - wireless router - WWAN - Wi-Fi 5 - desktop
Wireless router - wireless cellular modem - 6-port switch (integrated)
Enclosure Type
Desktop
Mobile Communication Protocol
HSPA+, LTE
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Performance
VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (SSL): 120 Mbps , NAT throughput for dual WAN with hardware acceleration: 1.8 Gbps , NAT throughput for single WAN with hardware acceleration: 950 Mbps , NAT throughput: 800 Mbps
Concurrent VPN tunnels: 50 , Concurrent SSL VPN tunnels: 25 , NAT sessions: 60000 , Hardware accelerated NAT sessions: 8000
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP, DNS, DDNS, DHCPv6, IPv4, IPv6
Routing Protocol
RIP, BGP, IGMPv2, IGMP, static IP routing, IGMPv3, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, CLI, TR-069, TR-104
NAT support, VPN support, load balancing, IGMP snooping, Syslog support, DoS attack prevention, content filtering, E-mail alert, print server, MAC address filtering, VPN passthrough, WDS support, firmware upgradable, DDos attack prevention, wall mountable, tunnelling, WMM support, file sharing, QoS, DPD, IPSec NAT-T, roaming function, WAN failover, DHCP server, Multiple SSID support, hidden SSID, reset button, Wireless Client Mode, SPIF, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, DHCP client, tagged VLAN, IGMP proxy, MIB II, DMZ support, VLAN Tagging, port-based VLAN, Wireless Mesh support, WLAN/WPS button, 2x2 MIMO technology, 4x4 MIMO technology, DSCP based QoS
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac Wave 2
AC 230V
24.1 cm x 16.5 cm x 4.4 cm
United Kingdom
Wireless router - 6-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MPPE, 128-bit WEP, 64-bit WEP, SSL, SHA-1, WPA, WPA2, 128-bit AES, 192-bit AES, 256-bit AES, IKEv2, IKEv1, SHA-256
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID), TACACS+, LDAP
Wi-Fi Rating
AC1300
Built-in Devices
Led panel
Status Indicators
Active, WAN, DMZ, USB, LTE, 5 GHz, 2.4 GHz, QoS
Communications
Wireless cellular modem
HSPA+, LTE
Max Transfer Rate
300 Mbps
LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A , Antenna: 4 x
Expansion Slots
1 (total) / 1 (free) x SIM
External power adapter
AC 230V
2 aerial magnetic extension bases, 2 x WiFi aerials, 2 x LTE aerials
2 x aerial extension cable - 1 m
United Kingdom
24.1 cm
16.5 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: Ethernet
Standards: IEEE 802.11b
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: PPP
Standards: IEEE 802.11ac Wave 2
Speed: 300Mbps
Brand: DrayTek
