The DrayTek Vigor 2927ac - Dual-WAN Load Balancing Firewall VPN Router allows you to make the most of FTTP Fibre Broadband with Gigabit WAN throughput, extensive Firewall, Content Filtering, VPN client/server and Quality of Service controls.
The Vigor 2927ac has AC1300 Dual-Band wireless, providing fast and efficient wireless networking to your computers and devices. Multi-User MIMO (MU-MIMO) enables the router to send data to more than one client at a time.
The Vigor 2927ac provides a reliable, flexible, and secure network solution, that’s ideal for Small Business and Home Offices.
Dual Gigabit WAN Load Balancer
Route Policy - Powerful Routing Management
Wireless LAN
Ideal VPN router for SMB
Connect VPNs from behind NAT with DrayTek's VPN Matcher
Connecting Remote Sites with LAN to LAN VPN
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
5+1 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
Web Content Filtering with DNS Filter
DrayDDNS - DrayTek Dynamic DNS Address
High Availability - Hardware Failover
Manage Guest WiFi with Hotspot Web Portal
Quality of Service & Bandwidth Control
Central AP & Switch Management
Efficient connectivity
The Draytek Vigor 2927ac provides a variety of connection options with five interfaces, including WAN and LAN ports, enhancing network flexibility for multiple devices. -
Advanced security protocols
This router incorporates several encryption standards such as WPA2, ensuring secure data transfer and protecting user privacy effectively. -
High-performance wireless
Designed with dual-band capability and Wireless Protocol 802.11ac Wave 2, it delivers high-speed performance that supports demanding applications. -
Robust remote management
The Vigor 2927ac supports various remote management protocols, including HTTP, HTTPS, and SNMP 3, allowing users to easily manage their network from anywhere. -
Flexible antenna design
With external detachable antennas, users can customize their setup for improved signal reception and transmission, enhancing overall Wi-Fi coverage.
- Draytek Vigor 2927ac - wireless router - Wi-Fi 5 - desktop
- Wireless router - 6-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (IPSec): 800 Mbps , VPN throughput (SSL): 120 Mbps , NAT throughput for single WAN with hardware acceleration: 950 Mbps , NAT throughput for dual WAN with hardware acceleration: 1.8 Gbps , NAT throughput: 800 Mbps , Maximum data rate (5 GHz): 866 Mbps , Maximum data rate (2.4 GHz): 400 Mbps
- Capacity
- Concurrent VPN tunnels: 50 , Concurrent SSL VPN tunnels: 25 , NAT sessions: 60000 , Hardware accelerated NAT sessions: 8000 , SSIDs per radio: 4 , SIP registrars: 12
- PPTP, L2TP, IPSec, PPPoE, DNS, DDNS, DHCPv6, IPv4, IPv6
- Routing Protocol
- RIP-1, RIP-2, BGP, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), RIPng
- Remote Management Protocol
- SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH, TR-069
- Firewall protection, NAT support, VPN support, load balancing, IGMP snooping, Syslog support, SPI, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, print server, MAC address filtering, VPN passthrough, firmware upgradable, DDos attack prevention, wall mountable, LAN-to-LAN bridging, tunnelling, WMM support, file sharing, QoS, dual WAN connection, DPD, IPSec NAT-T, WPS, WAN failover, DHCP server, reset button, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, DHCP client, IGMP proxy, MU-MIMO technology, beamforming technology, band steering, IGMP fast leave, Airtime Fairness, DMZ support, VLAN Tagging, port-based VLAN, DNSSEC support, DHCP over IPSec, PPP, DSCP based QoS, Brute Force Protection
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x
- Power
- AC 230V
- 24.1 cm x 16.5 cm x 4.4 cm
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- Performance
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MPPE, IKE, SSL, SHA-1, WPA, WPA2, 128-bit AES, 192-bit AES, 256-bit AES, IKEv2, WEP, WPA3, SHA-256
- Authentication Method
- RADIUS, X.509 certificates, TACACS+, LDAP
- Wi-Fi Rating
- AC1300
- Built-in Devices
- Led panel
- Status Indicators
- WAN, DMZ, link/activity, USB, 5 GHz, 2.4 GHz, QoS
- LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Power Device
- External power adapter
- Voltage Required
- AC 230V
- Cables Included
- 1 x network cable - 2 m
- Localisation
- United Kingdom
- 24.1 cm
- 16.5 cm
- 4.4 cm
- Limited warranty - 2 years
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
