DrayTek Vigor 2927AC WiFi Router
Quicklinx: G4XMWS00 Mfr#: V2927AC-K
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11n, Ethernet, Gigabit Ethernet, IEEE 802.11a + 4 more
Speed: 866Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£247.31 ex VAT
£296.77 inc VAT
The DrayTek Vigor 2927ac - Dual-WAN Load Balancing Firewall VPN Router allows you to make the most of FTTP Fibre Broadband with Gigabit WAN throughput, extensive Firewall, Content Filtering, VPN client/server and Quality of Service controls.
The Vigor 2927ac has AC1300 Dual-Band wireless, providing fast and efficient wireless networking to your computers and devices. Multi-User MIMO (MU-MIMO) enables the router to send data to more than one client at a time.
The Vigor 2927ac provides a reliable, flexible, and secure network solution, that’s ideal for Small Business and Home Offices.
Dual Gigabit WAN Load Balancer
Route Policy - Powerful Routing Management
Wireless LAN
Ideal VPN router for SMB
Connect VPNs from behind NAT with DrayTek's VPN Matcher
Connecting Remote Sites with LAN to LAN VPN
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
5+1 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
Web Content Filtering with DNS Filter
DrayDDNS - DrayTek Dynamic DNS Address
High Availability - Hardware Failover
Manage Guest WiFi with Hotspot Web Portal
Quality of Service & Bandwidth Control
Central AP & Switch Management
  • Efficient connectivity
    The Draytek Vigor 2927ac provides a variety of connection options with five interfaces, including WAN and LAN ports, enhancing network flexibility for multiple devices.
  • Advanced security protocols
    This router incorporates several encryption standards such as WPA2, ensuring secure data transfer and protecting user privacy effectively.
  • High-performance wireless
    Designed with dual-band capability and Wireless Protocol 802.11ac Wave 2, it delivers high-speed performance that supports demanding applications.
  • Robust remote management
    The Vigor 2927ac supports various remote management protocols, including HTTP, HTTPS, and SNMP 3, allowing users to easily manage their network from anywhere.
  • Flexible antenna design
    With external detachable antennas, users can customize their setup for improved signal reception and transmission, enhancing overall Wi-Fi coverage.
Draytek Vigor 2927ac - wireless router - Wi-Fi 5 - desktop
Wireless router - 6-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Performance
VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (IPSec): 800 Mbps , VPN throughput (SSL): 120 Mbps , NAT throughput for single WAN with hardware acceleration: 950 Mbps , NAT throughput for dual WAN with hardware acceleration: 1.8 Gbps , NAT throughput: 800 Mbps , Maximum data rate (5 GHz): 866 Mbps , Maximum data rate (2.4 GHz): 400 Mbps
Concurrent VPN tunnels: 50 , Concurrent SSL VPN tunnels: 25 , NAT sessions: 60000 , Hardware accelerated NAT sessions: 8000 , SSIDs per radio: 4 , SIP registrars: 12
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DNS, DDNS, DHCPv6, IPv4, IPv6
Routing Protocol
RIP-1, RIP-2, BGP, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), RIPng
Remote Management Protocol
SNMP 1, SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH, TR-069
Firewall protection, NAT support, VPN support, load balancing, IGMP snooping, Syslog support, SPI, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, print server, MAC address filtering, VPN passthrough, firmware upgradable, DDos attack prevention, wall mountable, LAN-to-LAN bridging, tunnelling, WMM support, file sharing, QoS, dual WAN connection, DPD, IPSec NAT-T, WPS, WAN failover, DHCP server, reset button, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, DHCP client, IGMP proxy, MU-MIMO technology, beamforming technology, band steering, IGMP fast leave, Airtime Fairness, DMZ support, VLAN Tagging, port-based VLAN, DNSSEC support, DHCP over IPSec, PPP, DSCP based QoS, Brute Force Protection
IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x
AC 230V
24.1 cm x 16.5 cm x 4.4 cm
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MPPE, IKE, SSL, SHA-1, WPA, WPA2, 128-bit AES, 192-bit AES, 256-bit AES, IKEv2, WEP, WPA3, SHA-256
Authentication Method
RADIUS, X.509 certificates, TACACS+, LDAP
Wi-Fi Rating
AC1300
Built-in Devices
Led panel
Status Indicators
WAN, DMZ, link/activity, USB, 5 GHz, 2.4 GHz, QoS
LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
AC 230V
1 x network cable - 2 m
United Kingdom
24.1 cm
16.5 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: Fast Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11ac Wave 2
Speed: 866Mbps
Brand: DrayTek
