DrayTek Vigor 2927 Router
Quicklinx: G4XLWS00 Mfr#: V2927-K
Type: Router
Connection Type: WAN/LAN
Standards: Gigabit Ethernet, Ethernet, Fast Ethernet
Speed: 800
Rackmount or External: Desktop
Hurry, only 3 left in stock!
£194.62 ex VAT
£233.54 inc VAT
The DrayTek Vigor 2927 - Dual-WAN Load Balancing Firewall VPN router allows you to make the most of FTTP Fibre Broadband with Gigabit WAN throughput, extensive Firewall, Content Filtering, VPN client/server and Quality of Service controls.
The Vigor 2927 provides a reliable, flexible, and secure network solution, that’s ideal for Small Business and Home Offices.
Route Policy - Powerful Routing Management
Ideal VPN router for SMB
Connecting Remote Sites with LAN to LAN VPN
Connect VPNs from behind NAT with DrayTek's VPN Matcher
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
5+1 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
Web Content Filtering with DNS Filter
DrayDDNS - DrayTek Dynamic DNS Address
High Availability - Hardware Failover
Manage Guest WiFi with Hotspot Web Portal
Quality of Service & Bandwidth Control
Central AP & Switch Management
Draytek Vigor 2927 - router - desktop
Router - 6-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Performance
VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (IPSec): 800 Mbps , VPN throughput (SSL): 120 Mbps , NAT throughput for single WAN with hardware acceleration: 950 Mbps , NAT throughput for dual WAN with hardware acceleration: 1.8 Gbps , NAT throughput: 800 Mbps
Concurrent VPN tunnels: 50 , Concurrent SSL VPN tunnels: 25 , NAT sessions: 60000 , Hardware accelerated NAT sessions: 8000
Network / Transport Protocol
PPTP, L2TP, PPPoE, IPSec, DHCPv6, IPv4, IPv6, DNS, DDNS
Routing Protocol
RIP-2, static IPv6 routing, RIP-1, BGP, RIPng, static IPv4 routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, SNMP 3, Telnet, SSH, HTTP, HTTPS, TR-069, SNMP 1
3G/4G USB Dongle Support, DDos attack prevention, DPD, DHCP client, DHCP over IPSec, DHCP server, DMZ support, DoS attack prevention, E-mail alert, firewall protection, anti-spoofing protection, IP-MAC binding, IPSec NAT-T, MAC address filtering, port-based VLAN, SPI, Syslog support, VPN passthrough, DSCP based QoS, IGMP snooping, QoS, WAN failover, dual WAN connection, print server, VPN support, load balancing, NAT support, IGMP proxy, reset button, file sharing, VLAN Tagging, content filtering, tunnelling, port mirroring, firmware upgradable, wall mountable, DNSSEC support, IGMP fast leave, PPP, LAN-to-LAN bridging, ALG support
IEEE 802.1x, IEEE 802.1Q, IEEE 802.1p
AC 230V
24.1 cm x 16.5 cm x 4.4 cm
United Kingdom
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
MPPE, DES, Triple DES, SHA-1, IKE, IKEv2, SSL, SHA-256, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
X.509 certificates, RADIUS, TACACS+, LDAP
Built-in Devices
Led panel
Status Indicators
WAN, USB, link/activity, DMZ
LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
AC 230V
1 x network cable - 2 m
United Kingdom
24.1 cm
16.5 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Speed: 800
Brand: DrayTek
