DrayTek Vigor 2926 Dual-WAN Router
Quicklinx: DB4YWS00 Mfr#: V2926-K
Vigor 2926 Series Ethernet Router Firewall & Load-Balancer
The Vigor 2926 series is our dual-Ethernet WAN firewall for load-balancing or failover. It's also a fully featured firewall, VPN concentrator and content filtering device.
This latest router series includes support for professional features such as VLAN tagging, Gigabit Ethernet, built-in wireless LAN (Vigor 2926n or Vigor 2926ac). An alternative WAN connectivity is by a USB 3G/4G/LTE cellular modem which can be your primary WAN feed, backup or load-balanced with your fixed line.
A 5-port Gigabit Ethernet switch on the LAN side provides high speed connectivity for your server, other local PCs or for uplink to a larger Ethernet switch. Comprehensive security features include content filtering, web application controls and an object based firewall management system. Port 5 is switchable with 'WAN2' to use it as an Ethernet WAN port instead of a LAN port (requires f/w 3.8.8 or later, otherwise 5th Ethernet port is for WAN2 only.)
Robust & Comprehensive Firewall
Security is always taken seriously with DrayTek routers. The firewall protects against attacks including DoS (Denial of Service) attacks, IP-based attacks and access by unauthorised remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organisations. The Vigor 2926 also allows selective direction firewall rules of LAN to WAN, WAN to LAN or LAN to LAN/VPN.
Central Management with VigorACS
The Vigor 2926 series (along with most other DrayTek routers, Access points and switches) can be centrally managed by our VigorACS central management platform. This scalable solution provides visibility, control and reporting of your entire DrayTek product estate, ideal for dealers/SIs manageing customers' devices or any user who wants to know what's going on with their devices. VigorACS also provides features like automated/bulk firmware updates, VPN management and alarms for connectivity or other issues.
Web Content Filtering
The content control features of the Vigor 2926 series allows you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites with whitelists or blacklists, blocking IM/P2P applications or other potentially harmful or wasteful content. Restrictions can be per user, per PC or universal and according to time schedules. Content filtering can also block sites using HTTPS/SSL where URLs are encrypted (and normal routers cannot block).
User Management/Authentication
The Vigor 2926 has built-in user management which allows you to provide conditional internet access with Time and Data usage quotas to different users, based on their own unique login (stored in the router, or on an external Radius server).
Rack Mounting Kit
The RM1 Rackmount Bracket enables you to fit any Vigor 2926 series router into a standard 19" rack or cabinet. The bracket takes up one rack slot (1U) and includes a cable retainer at the back to keep the power cord captive. The front mounted sockets of the router remain fully accessible. For wireless models, we then recommend extension aerials (or aerial extensions).
USB Port for Ad-Hoc Storage / Logging
The Vigor 2926's USB port can also be used to add storage memory to the unit in the form of a USB memory key (as shown right). The Vigor 2926 then provides FTP access file uploading/downloading which can be from the local LAN or from anywhere on the Internet - ideal for a simple to deploy file depository. If you do have a USB memory key connected, you can also have the router save it's system logs (syslog) to that memory instead of to a connecting computer; useful for technical personnel (SysAdmins).
Draytek Vigor 2926 - router - desktop
Router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
VPN tunnels: 50 , Concurrent VPN tunnels: 50 , Concurrent SSL VPN tunnels: 25
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, DHCPv6
Routing Protocol
RIP-2, static IP routing
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
DMZ port, IGMP snooping, Syslog support, DoS attack prevention, content filtering, DiffServ support, print server, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, Outbound Load Balancing, firmware upgradable, DDos attack prevention, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), dual WAN connection, Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, DHCP server, Samba support, SMS alert, DNS proxy, Bandwidth-On-Demand (BOD), IPv4 support, DHCP relay, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, DHCP client, tagged VLAN, IM/P2P filter, DNS caching, Content Security Management (CSM)
IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, UPnP
16.5 cm x 24.1 cm x 4.4 cm
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, IKE, SHA-1
Authentication Method
RADIUS, X.509 certificates, TACACS+, LDAP, Active Directory
Status Indicators
WAN, DMZ, link/activity, USB, VPN
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
External power adapter
24 Watt
16.5 cm
24.1 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
