DrayTek Vigor 2865LAC LTE WLAN Router
Quicklinx: G9LNWS00 Mfr#: V2865LAC-K
Type: Router
Connection Type: ADSL or VDSL
Standards: Gigabit Ethernet, Fast Ethernet, IEEE 802.11n, IEEE 802.11g + 5 more
Speed: 300Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
More than 50 In Stock
£460.22 ex VAT
£552.26 inc VAT
The Ideal DSL Router with VPN for Small Business and Remote Working
DrayTek’s Vigor 2865 series Multi-WAN Firewall VPN routers are ideal for Superfast VDSL Broadband and Ethernet-based FTTP Fibre Broadband. With Gigabit throughput, Quality of Service, VPN client/server, comprehensive Firewall and Content Filtering controls.
Wi-Fi is available on ‘ac’ models and the integrated 4G+ LTE modem on ‘Lac’ models takes full advantage of mobile broadband. The Vigor 2865 series provides a reliable, flexible, and secure networking solution, that’s ideal for Home Offices, Small Business and Satellite Offices.
VDSL and Ethernet Load Balancer
Route Policy - Powerful Routing Management
Integrated LTE 4G/3G Modem
Constant Connectivity - Dual-SIM LTE
AC1300 Wireless LAN with Mesh
Ideal VPN router for SMB
Connect VPNs from behind NAT with DrayTek's VPN Matcher
Connecting Remote Sites with LAN to LAN VPN
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
5+1 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
Web Content Filtering with DNS Filter
High Availability - Hardware Failover
DrayDDNS - DrayTek Dynamic DNS Address
Manage Guest WiFi with Hotspot Web Portal
Quality of Service & Bandwidth Control
Central AP & Switch Management
  • VDSL and Ethernet Load Balancer
    Connect the Vigor 2865 to Superfast Fibre with the integrated VDSL modem. Use the Ethernet WAN with cable and Ultrafast FTTP. Load Balance multiple connections to boost performance.
  • Dual-SIM 4G+ LTE modem
    Ensure ultra-reliable connectivity with an integrated high-performance 4G+/LTE Category 6 modem. Handle mobile network outages with Dual-SIM Failover.
  • Packed with features
    Take advantage of DrayTek's rich feature set and useful functionality such as Quality of Service, Route Policy, Hotspot Web Portal, VPN Matcher, DrayDDNS and more.
  • Robust SMB VPN router
    Quickly and securely connect remote sites with up to 32 VPN tunnels. Enable remote workers to access resources with DrayTek SSL VPN and OpenVPN support.
  • 5+1 Gigabit LAN ports with VLANs
    Link server, computers, and network attached storage directly, with up to 6 Gigabit LAN ports. VLANs allow for as many as 8 separate networks, with options for Hotspot Captive Portal.
  • VigorACS central management
    The Vigor 2865 can be fully managed and configured remotely with the VigorACS central management platform. Manage DrayTek networks spanning multiple sites.
Draytek Vigor 2865Lac - router - DSL/WWAN - Wi-Fi 5 - desktop
Router - DSL modem / wireless cellular modem - 6-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, VDSL2, Vplus 35b
Mobile Communication Protocol
LTE
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Concurrent VPN tunnels: 32 , NAT sessions: 50000 , Concurrent SSL VPN tunnels: 16
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, ARP, FTP, DHCP, DNS, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6
Routing Protocol
RIP, BGP, GRE, static IPv4 routing, static IPv6 routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069
VoIP Protocols
H.323, SIP
Firewall protection, load balancing, IGMP snooping, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, IPv6 support, VPN passthrough, High Availability, WDS support, URL filtering, firmware upgradable, WMM support, ACL support, QoS, IPSec NAT-T, WPS, IPSec passthrough, DHCP server, SMS alert, hidden SSID, reset button, bandwidth control, IPv4 support, DNS server, port triggering, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, application filtering, IGMP proxy, 802.1x authentication, ToS, PBC, L2TP passthrough, band steering, WDS bridge, Web Filtering, IGMP fast leave, Airtime Fairness, 2x2 MU-MIMO technology, L2TP over IPSec, client isolation, DMZ support, VLAN Tagging, port-based VLAN, port-based QoS, WDS repeater mode, multiple PVC support, broadcast threshold, DNS filtering, 2x2 MIMO technology, DNSSEC support, WLAN scheduling, DSCP based QoS, Brute Force Protection
IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.1x, UPnP
24.1 cm x 16.5 cm x 4.4 cm
620 g
United Kingdom, Ireland
Router - 6-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Encryption Algorithm
DES, Triple DES, MPPE, AES, SSL, SHA-1, WPA, WPA2, IKEv2, 256-bit SHA, WEP
Authentication Method
RADIUS, X.509 certificates, TACACS+, LDAP, internal user database, XAUTH authentication
Status Indicators
WAN, DMZ, link/activity, USB, DSL, 5 GHz, 2.4 GHz, QoS
Line Properties
Framing Format
ANSI T1.413
Communications
LTE
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.5, ITU G.993.2, ITU G.993.5, ITU G.992.3
Max Transfer Rate
300 Mbps
IP Telephony
VoIP Protocols
H.323, SIP
LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
Expansion Slots
2 SIM
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
1 x modem cable
OS Provided
No operating system
24.1 cm
16.5 cm
4.4 cm
620 g
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: Fast Ethernet
Standards: IEEE 802.11n
Standards: IEEE 802.11g
Standards: Ethernet
Standards: PPP
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11ac Wave 2
Speed: 300Mbps
Brand: DrayTek
