DrayTek Vigor 2865AC WLAN Router
Quicklinx: G9LMWS00 Mfr#: V2865AC-K
  • IEEE 802.11n
Vigor 2865 series is a VDSL2 35b/ADSL2+ security firewall router integrating a DSL modem which is compatible with variants of ADSL and VDSL, including profile 35b supervectoring. There is also a Gigabit Ethernet WAN port for broadband connections to share the traffic load or serve as a failover connection. A 3G/4G/LTE USB modem can also be attached to the USB ports of the router. This model features built-in 802.11ac Wave 2 Wi-Fi.
  • Load balancing
    Maximize throughput and reliability by using multiple Internet connections.
  • 35b supervectoring modem
    Integrated VDSL modem supporting VDSL2 profile 35b supervectoring.
  • VPN (Virtual Private Network)
    Build a secure and private tunnel from the LAN of Vigor 2865 to remote offices and teleworkers over the Internet.
  • SSL VPN
    The VPN works through firewalls providing secure remote access to any network environment.
  • Firewall and content filter
    Filter web pages by URL keyword or web category to block access to insecure or inappropriate content.
  • Dray DDNS
    The DDNS service for you to access the router by a fixed hostname of your choice.
  • Wireless WAN
    Get Internet access wirelessly from a Wi-Fi network, a mobile hotspot, or a personal hotspot setup on smartphones.
  • Hotspot web portal
    Market your business and communicate with the guests while offering hospitality Wi-Fi.
  • Bandwidth management
    Prevent one device using all the bandwidth by bandwidth limit policy, session limit policy, and QoS settings.
  • Central AP management
    Use the Vigor 2865 router as a wireless controller to maintain and monitor the Vigor APs.
  • Central switch management
    Set up VLAN easily from the router and get a centralized hierarchy view of the switches.
Draytek Vigor 2865ac - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem - 5-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
H.323, ADSL, SIP, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Performance
VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (SSL): 130 Mbps , NAT throughput: 800 Mbps
Concurrent SSL VPN tunnels: 16 , Concurrent VPN tunnels: 32 , NAT sessions: 60000 , VLANs supported: 16 , SSIDs per radio: 4
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, ARP, FTP, DHCP, DNS, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6
Routing Protocol
RIP, BGP, GRE, static IPv4 routing, static IPv6 routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069
Firewall protection, load balancing, IGMP snooping, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, IPv6 support, VPN passthrough, High Availability, WDS support, URL filtering, firmware upgradable, WMM support, ACL support, QoS, IPSec NAT-T, WPS, IPSec passthrough, DHCP server, SMS alert, hidden SSID, reset button, bandwidth control, IPv4 support, DNS server, port triggering, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, application filtering, IGMP proxy, 802.1x authentication, ToS, PBC, L2TP passthrough, band steering, WDS bridge, Web Filtering, IGMP fast leave, Airtime Fairness, 2x2 MU-MIMO technology, L2TP over IPSec, client isolation, DMZ support, VLAN Tagging, port-based VLAN, port-based QoS, WDS repeater mode, multiple PVC support, broadcast threshold, DNS filtering, 2x2 MIMO technology, DNSSEC support, WLAN scheduling, DSCP based QoS, Brute Force Protection
IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.1x, UPnP
24.1 cm x 16.6 cm x 4.6 cm
620 g
United Kingdom, Ireland
Wireless router - 5-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MPPE, AES, SSL, SHA-1, WPA, WPA2, IKEv2, 256-bit SHA, WEP
Authentication Method
RADIUS, X.509 certificates, TACACS+, LDAP, XAUTH authentication, SMS passcode
Status Indicators
WAN, DMZ, link/activity, USB, DSL, 5 GHz, 2.4 GHz, QoS
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.993.2, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.993.5
Max Transfer Rate
300 Mbps
LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
24 Watt
1 x modem cable
24.1 cm
16.6 cm
4.6 cm
620 g
45 °C
10 - 90% (non-condensing)
