DrayTek Vigor 2865 VDSL Router
Quicklinx: G4XQWS00 Mfr#: V2865-K
Type: Router
Connection Type: ADSL, ADSL2+, VDSL2 and Fibre
Standards: Ethernet, Gigabit Ethernet, PPP, Fast Ethernet
Speed: 300Mbps
Rackmount or External: Desktop
More than 50 In Stock
£212.90 ex VAT
£255.48 inc VAT
DrayTek’s Vigor 2865 series Multi-WAN Firewall VPN routers are ideal for Superfast VDSL Broadband and Ethernet-based FTTP Fibre Broadband. With Gigabit throughput, Quality of Service, VPN client/server, comprehensive Firewall and Content Filtering controls.
Options for Wi-Fi 6 on ‘ax’ models, or Wi-Fi 5 ‘ac’ models provide fast & efficient wireless connectivity, while the integrated 4G+ LTE modem on ‘Lac’ models takes full advantage of mobile broadband. The Vigor 2865 series provides a reliable, flexible, and secure networking solution, that’s ideal for Home Offices, Small Business and Satellite Offices.
VDSL and Ethernet Load Balancer
Route Policy - Powerful Routing Management
Integrated LTE 4G/3G Modem
Constant Connectivity - Dual-SIM LTE
Mesh Wireless
Wi-Fi 6 - AX3000 Performance
AC1300 Wireless LAN
Ideal VPN router for SMB
Connect VPNs from behind NAT with DrayTek's VPN Matcher
Connecting Remote Sites with LAN to LAN VPN
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
5+1 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
Web Content Filtering with DNS Filter
High Availability - Hardware Failover
DrayDDNS - DrayTek Dynamic DNS Address
Manage Guest WiFi with Hotspot Web Portal
Quality of Service & Bandwidth Control
Central AP & Switch Management
  • VDSL and Ethernet Load Balancer
    Connect the Vigor 2865 to Superfast Fibre with the integrated VDSL modem. Use the Ethernet WAN with cable and Ultrafast FTTP. Load Balance multiple connections to boost performance.
  • 5G/LTE router with dual SIM slot
    Integrated 5G/LTE modem supporting LTE Category 19. Unlocked to any network. Backward compatible with 4G/LTE.
  • Wi-Fi 6 - AX3000 performance
    Wi-Fi 6 wireless provides Gigabit Wi-Fi with reliable throughput. Ideal for time-sensitive video conferencing, low latency gaming and handling 4K Ultra HD streaming, without buffering.
  • Robust SMB VPN router
    Quickly and securely connect remote sites with up to 32 VPN tunnels. Enable remote workers to access resources with DrayTek SSL VPN and OpenVPN support.
  • 5+1 Gigabit LAN ports with VLANs
    Link server, computers, and network attached storage directly, with up to 6 Gigabit LAN ports. VLANs allow for as many as 8 separate networks, with options for Hotspot Captive Portal.
  • VigorACS SD-WAN central management
    Manage the Vigor 2865 remotely and utilize DrayTek's powerful SD-WAN features with the VigorACS 3 management platform. Centrally manage and provision whole networks across multiple sites.
Draytek Vigor 2865 - router - DSL modem - desktop
Router - DSL modem
Enclosure Type
Desktop
Digital Signaling Protocol
VDSL2, ADSL2+, Vplus 35b, ADSL2, ADSL, VDSL
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, PPP
Performance
VPN throughput (256-bit AES IPSec): 300 Mbps , VPN throughput (SSL): 120 Mbps , NAT throughput: 800 Mbps
VLANs supported: 16 , Concurrent VPN tunnels: 32 , NAT sessions: 60000 , Concurrent SSL VPN tunnels: 16
Network / Transport Protocol
IPSec, DDNS, DHCP, PPPoE, PPTP, L2TP, IPv4, IPv6, DHCPv6, Bonjour, SMB, RTSP, FTP
Routing Protocol
Static IPv4 routing, static IPv6 routing, RIP, BGP, policy-based routing (PBR), GRE
Remote Management Protocol
Telnet, HTTP, HTTPS, SSH, TR-069, TFTP, SNMP 1, SNMP 2c, SNMP 3
VoIP Protocols
SIP, H.323
Firewall protection, 3G/4G USB Dongle Support, VPN support, reset button, load balancing, content filtering, DynDNS, bandwidth control, DHCP server, IPv6 support, IPv4 support, VLAN Tagging, ARP support, port-based VLAN, IP-MAC binding, port mirroring, DNS server, High Availability, IGMP proxy, IGMP snooping, file sharing, LAN-to-LAN bridging, GRE, IPSec NAT-T, failover protection, port triggering, DMZ support, ALG support, VPN passthrough, application filtering, URL filtering, Web Filtering, anti-spoofing protection, DoS attack prevention, QoS, ToS, DSCP support, DSCP based ToS, ACL support, Brute Force Protection, E-mail alert, SMS alert, Syslog support, tagged VLAN, keyword filtering
ANSI T1.413, IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, UPnP
24.1 cm x 16.6 cm x 4.6 cm
620 g
United Kingdom, Ireland
Router
Enclosure Type
Desktop
Wired
Performance
Routing Protocol
Encryption Algorithm
SSL, IKEv2, SHA-1, 256-bit SHA, DES, Triple DES, AES, MPPE
Authentication Method
RADIUS, XAUTH authentication, internal user database, LDAP, TACACS+, X.509 certificates
Built-in Devices
Led panel
Status Indicators
DMZ, DSL, link/activity, USB, VPN, WAN
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.993.2, ITU G.993.5, ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A, ITU G.992.5 Annex A
Max Transfer Rate
300 Mbps
IP Telephony
VoIP Protocols
SIP, H.323
LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A
External power adapter
1 x modem cable
OS Provided
No operating system
24.1 cm
16.6 cm
4.6 cm
620 g
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Gigabit Ethernet
Standards: PPP
Standards: Fast Ethernet
Speed: 300Mbps
Brand: DrayTek
