DrayTek Vigor 2832n ADSL Router w/Wireless
Quicklinx: C93BWS00 Mfr#: V2832N-K
Type: Wireless router
Connection Type: ADSL or VDSL
Standards: Gigabit Ethernet, IEEE 802.11g, IEEE 802.11n, Ethernet + 2 more
Speed: 200Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£188.17 ex VAT
£225.80 inc VAT
The Vigor 2832 features a hugely flexible VLAN system. In its simplest form, each of the four Gigabit LAN ports can be isolated from each other, for example to feed different companies or departments but keeping their local traffic completely separated. For more sophisticated scenarios, the Vigor 2832 includes tagged VLANs (802.1q) whereby data is marked with a VLAN identifier. This identifier can be read by an onward Ethernet switch and directed to specific ports or just passed to the LAN for specific VLAN clients to pick up; priorities can also be applied for LAN-side QoS.
Draytek Vigor 2832n - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
NAT sessions: 50000 , Concurrent VPN tunnels: 32 , SSL VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, IPSec
Routing Protocol
RIP
Remote Management Protocol
SNMP 3, HTTP, HTTPS, TFTP, CLI, TR-069
Firewall protection, content filtering, dynamic DNS server, IPv6 support, VPN passthrough, URL filtering, wall mountable, LAN-to-LAN bridging, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, WAN failover, DHCP server, 2T2R MIMO technology, IPv4 support, DHCP relay, DHCP client, static routing, WAN load balancing, keyword filtering
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11e, IEEE 802.11n
AC 230V
16.507 cm x 24.096 cm x 4.396 cm
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
PPTP, L2TP, IPSec
Routing Protocol
RIP
Encryption Algorithm
MD5, WPA, WPA2, WEP
Communications
DSL modem
USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x ADSL2+ - RJ-11 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
AC 230V
18 Watt
United Kingdom
16.507 cm
24.096 cm
4.396 cm
45 °C
10 - 90% (non-condensing)
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11b
Speed: 200Mbps
Brand: DrayTek
