DrayTek Vigor 2765ac VDSL WLAN Router
Quicklinx: G7Z1WS00 Mfr#: V2765AC-K
  • IEEE 802.11n
£176.34 ex VAT
£211.60 inc VAT
Vigor2765 Series is a 35b Supervectoring VDSL modem, a firewall, and a VPN router. The router has four GbE LAN ports, one of which is switchable to be a backup WAN interface. It's highly configurable for an abundance of features including web content filtering, bandwidth limit, QoS and lots more, perfect for professional users who would like to take full control of the network.
Draytek Vigor 2765ac - wireless router - DSL modem - Wi-Fi 5 - desktop
Wireless router - DSL modem
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2, ADSL2+, VDSL2, Vplus 35b
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Performance
VPN throughput (256-bit AES IPSec): 200 Mbps , VPN throughput (SSL): 80 Mbps , NAT throughput: 600 Mbps
VLANs supported: 8 , Concurrent VPN tunnels: 2 , NAT sessions: 50000 , SSIDs per radio: 4
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, FTP, DHCP, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6
Routing Protocol
RIP, MPOA, static IPv4 routing, static IPv6 routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069
VoIP Protocols
H.323, SIP
Firewall protection, VPN support, ARP support, IGMP snooping, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, print server, IPv6 support, VPN passthrough, URL filtering, LAN-to-LAN bridging, WMM support, file sharing, ACL support, QoS, IPSec NAT-T, WPS, DHCP server, SMS alert, reset button, bandwidth control, IPv4 support, DNS server, port triggering, 3G/4G USB Dongle Support, anti-spoofing protection, IP-MAC binding, application filtering, tagged VLAN, IGMP proxy, ToS, DSCP support, MU-MIMO technology, keyword filtering, beamforming technology, failover protection, Web Filtering, DMZ support, VLAN Tagging, port-based VLAN, DSCP based ToS, DynDNS, 2x2 MIMO technology, WPS button, Brute Force Protection
IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac Wave 2
20.7 cm x 13.1 cm x 4.2 cm
500 g
United Kingdom, Ireland
Wireless router
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, SSL, SHA-1, WPA, WPA2, WPA-PSK, 128-bit AES, 192-bit AES, 256-bit AES, WPA2-PSK, IKEv2, 256-bit SHA, WEP
Authentication Method
RADIUS, X.509 certificates, internal user database, XAUTH authentication
IEEE 802.1Q, ANSI T1.413, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac Wave 2, FCC
Built-in Devices
Led panel
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.997.1, ITU G.992.5, ITU G.993.1, ITU G.993.2, ITU G.992.3
Max Transfer Rate
300 Mbps
IP Telephony
VoIP Protocols
H.323, SIP
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A , Antenna: 2 x
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
19 Watt
2 x WiFi aerials
1 x modem cable , 1 x network cable
20.7 cm
13.1 cm
4.2 cm
500 g
45 °C
10 - 90% (non-condensing)
Type: Wireless router
Standards: Fast Ethernet
Standards: PPP
Standards: IEEE 802.11a
Standards: IEEE 802.11n
Standards: Ethernet
Standards: IEEE 802.11g
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11ac Wave 2
Brand: DrayTek
