DrayTek Vigor 2710 SoHo ADSL/2+ Router
Quicklinx: 62HQWS00 Mfr#: V2710
The Vigor 2710 is a highly integrated ADSL2/2+ router with VPN capability targeting SOHO (Small Office and Home Office) and residential broadband access requirement. These integrated network access devices not only offer rich functionality with up to 24Mbps bandwidth in downstream but also bandwidth management for multimedia applications. The integrated economical design makes the ideal balance of ease of use and secure network management.
Besides powerful firewall protection against malicious Denial of Service (Dos) attacks, the Vigor 2710 is designed with more advanced security feature such as Stateful Packet Inspection(SPI) to offer network reliability by detecting attacks and prohibits malicious penetrating packets from entering internal network.
The easy-to-use CSM (Content Security Management) can prevent family from the connection to web sites that contain illegal or objectionable content. The use of bandwidth/session consuming Peer-to-Peer (P2P) applications can be properly managed by embedded CSM.
You can attach USB storage device to USB port of Vigor 2710 to share files. Or, you can use USB printer by connecting it to USB port.
Draytek Vigor 2710 - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet
Network / Transport Protocol
L2TP, IPSec, PPPoE, PPPoA
Routing Protocol
RIP-2, static IP routing
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Firewall protection, DHCP support, NAT support, VPN support, IGMP snooping, Syslog support, SPI, DoS attack prevention, content filtering, E-mail alert, MAC address filtering, VPN passthrough, firmware upgradable, DDos attack prevention, wall mountable, TFTP support, QoS, DPD
UPnP
14.8 cm x 21.6 cm x 5.4 cm
Router - 4-port switch (integrated)
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, IKE, SHA-1
Authentication Method
RADIUS, X.509 certificates
UPnP, FCC
Communications
DSL modem
ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A , WAN: 1 x ADSL2+ - RJ-11
External power adapter
10 Watt
1 x network cable - 1.8 m , 1 x phone cable - 1.8 m
Mounting Kit
Included
Software Included
Drivers & Utilities
14.8 cm
21.6 cm
5.4 cm
45 °C
10 - 90%
