DrayTek Vigor 2620Ln
Quicklinx: F7L4WS00 Mfr#: V2620LN-K
Type: Wireless router
Connection Type: ADSL or VDSL
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b + 3 more
Speed: 300Mbps
Rackmount or External: Desktop
  • IEEE 802.11n
£213.98 ex VAT
£256.77 inc VAT
Vigor2620 LTE Series is a VDSL2/ADSL2+ modem router with embedded SIM card slots for 4G/LTE failover. It is equipped with 2x Gigabit Ethernet LAN ports, one of which is switchable to an additional backup WAN interface.
Vigor2620 LTE Series is a versatile router for a business network around 30 hosts. It can have two concurrent VPN tunnels to link to the main offices or provides remote access for Network Admins. It also offers the flexibility for network management, including Port Forwarding, SPI Firewall, Content Filtering, Bandwidth Management, QoS and more. The series includes models with built-in 11n Wi-Fi.
  • Embedded SIM slot
    Provide 4G/LTE Internet access for fixed line backup without the need for a USB dongle.
  • VPN (Virtual Private Network)
    Build a secure and private tunnel from the LAN of Vigor2620 LTE Series to the remote offices and teleworkers over the Internet.
  • Bandwidth management
    Prevent one device using all the bandwidth by bandwidth limit policy, session limit policy, and QoS settings.
  • Firewall & content filter
    Filter web pages by URL keyword or web category to block access to insecure or inappropriate contents.
  • DrayDDNS
    The free DDNS service for you to access the router by a fixed hostname of your choice.
  • Central AP management
    Use the Vigor2620 LTE Series router as a wireless controller to maintain and monitor the VigorAPs.
Draytek Vigor 2620Ln - wireless router - DSL/WWAN - Wi-Fi - desktop
Wireless router - DSL modem / wireless cellular modem - 2-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
VDSL2, ADSL2+, ADSL, ADSL2, VDSL
Mobile Communication Protocol
LTE
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, PPP, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Performance
VPN throughput (IPSec): 50 Mbps , VPN throughput (SSL): 25 Mbps , Firewall throughput: 300 Mbps
Concurrent VPN tunnels: 2 , NAT sessions: 30000 , SSIDs total: 4 , Port-pedirection entries: 40 , Open port entries: 40
Network / Transport Protocol
IPSec, DDNS, PPTP, L2TP, DHCP, DNS, PPPoE, PPPoA
Remote Management Protocol
Telnet, HTTP, HTTPS, CLI, TFTP, SNMP 2, SNMP 3, TR-069, TR-104, SSH
NAT support, VPN support, firewall protection, SMS remote control, VLAN support, VLAN Tagging, wireless bridge mode, IPv6 support, IPv4 support, DoS attack prevention, content filtering, bandwidth control, QoS, WPS, WPS button, reset button, black list, white list, MAC address filtering, WDS support, WMM support, DMZ support, ALGs, SPI, DDos attack prevention, anti-spoofing protection, Syslog support, E-mail alert, IP-MAC binding, CSM, URL filtering, Web Filtering, ToS, DSCP support, VPN passthrough, IPSec NAT-T, DPD, DHCP relay, port mirroring, DNS caching, DNS proxy, NTP client, MIB II, IGMP proxy, wall mountable, Multiple SSID support, DHCP server, TFTP support, firmware upgradable, IM/P2P filter, WAN failover
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.1p, ANSI T1.413i2
AC 230V
20.7 cm x 13.1 cm x 3.9 cm
440 g
United Kingdom, Ireland
Wireless router - 2-port switch (integrated)
Enclosure Type
Desktop
Wired, wireless
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Performance
Encryption Algorithm
SSL, 256-bit AES, WPA, WPA2, TLS, IKEv2, IKE, DES, Triple DES, 128-bit AES, 192-bit AES, SHA-1, 256-bit SHA, MD5
Authentication Method
X.509 certificates, Radio Service Set ID (SSID)
Built-in Devices
Led panel
Status Indicators
Power, Internet, DSL, LTE, LAN, SIM status, Wi-Fi
Line Properties
Framing Format
ANSI T1.413i2
Communications
LTE
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3, ITU G.992.5, ITU G.993.2, ITU G.993.1, ITU G.997.1
Max Transfer Rate
150 Mbps
LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Expansion Slots
2 (total) / 2 (free) x SIM
Aerial
Aerial
External detachable and internal
Antenna Qty
4
External power adapter
AC 230V
12 Watt
OS Provided
No operating system
20.7 cm
13.1 cm
3.9 cm
440 g
45 °C
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: PPP
Standards: IEEE 802.11n
Standards: IEEE 802.11g
Speed: 300Mbps
Brand: DrayTek
