DrayTek Vigor 2130n High Speed Router/Firewall IPv6 Wi-Fi
Quicklinx: 74TKWS00 Mfr#: V2130N
  • IEEE 802.11n (draft)
With the development of NGN (Next Generation Network), you may recently hear the news about FTTx deployment in your local area or even have already subscribed the unbundling last mile service from local ITSP for FTTx. As adopting FTTx, the main question for end users is whether your legacy router could fully utilize its bandwidth or not. For example, you purchase a 120Mbps Internet connection from your ISP, but your existing router can't support 90Mbps throughput. That's why DrayTek launches Vigor 2130 series - high speed Gigabit router, perfectly complied with VDSL2 environment. With high throughput performance and secured broadband connectivity provided by Vigor 2130 series, you can simultaneously engage these bandwidth-intensive applications, such as high-definition video streaming, online gaming, and Internet telephony/access.
  • Triple play for home entertainment and SOHO
    The entertainment applications running over the home network infrastructure and home-based productivity for SOHO are growing while the broadband bandwidth is increasingly available within affordable budget along with deployment of DSL or FTTx. The WAN port of Vigor 2130 series optimize the throughput performance and flexibility for time critical console gaming, multimedia streaming and P2P downloading as well as IP telephony.
  • Wireless coverage and security
    The DrayTek Vigor 2130n givers you not only the 802.11n Draft-n standard for coverage, but also the time scheduling functionality to save you energy bills plus reducing the carbon footprint. For wireless security, the DrayTek Vigor 2130n router is also efficient for wireless network management.
  • 3.5G USB modem as the backup Internet access
    DrayTek understands that sometimes users need to have Internet access available when moving into premise or keep online even during the downtime of a fixed broadband line. The DrayTek Vigor 2130n has 2 USB ports to connect either a USB printer and/or a 3G USB modem as a second WAN, this can be used as a back up if the installation of DSL/cable Internet is not available or the fixed broadband line drops.
Draytek Vigor 2130n - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Performance
WAN throughput: 800 Mbps
Simultaneous NAT sessions: 15000
Network / Transport Protocol
PPTP, L2TP, IPSec
Remote Management Protocol
SNMP, Telnet, HTTP
Firewall protection, auto-sensing per device, NAT support, VPN support, Syslog support, DoS attack prevention, content filtering, IPv6 support, VPN passthrough, WDS support, URL filtering, IP address filtering, firmware upgradable, DDos attack prevention, WMM support, ACL support, WPS, DHCP server, port forwarding
IEEE 802.3, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft), UPnP
Apple MacOS 8.0, Microsoft Windows 95/98, Linux, Apple MacOS 9, Microsoft Windows 2000 / NT4.0, Microsoft Windows Millennium Edition, Apple MacOS X, Microsoft Windows XP
Enclosure Type
Desktop
Wireless, wired
Performance
PPTP, L2TP, IPSec
SNMP, Telnet, HTTP
Encryption Algorithm
DES, Triple DES, MD5, MPPE, SHA-1, WPA
Authentication Method
X.509 certificates
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
1 x network cable - 1.8 m , 1 x modem cable - 1.8 m
Mounting Kit
Included
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
