DrayTek Vigor 2110n SoHo Router
Quicklinx: 62HMWS00 Mfr#: V2110N
  • Wi-Fi CERTIFIED
  • IEEE 802.11n (draft 2.0)
The Vigor2110n is a user-friendly broadband router with advanced bandwidth control mechanism and 2 VPN tunnels for secured remote access. Vigor2110n complies with 802.11n Draft-n standards. The wireless LAN isolation, Mac address control, and WEP/WPA/WPA2 encryption let you easily set up wireless network for your home.
The Vigor2110n's firewall provides the ideal balance of ease of use and security to help protect your network. The CSM (content security management) can prevent family from the connection to web sites that contain illegal or objectionable content. The use of bandwidth consuming peer-to-peer (P2P) applications can be properly managed by embedded CSM.
The Vigor2110n takes care of all your teleworking needs, with support of 2 simultaneous VPN connections. You can establish remote access or LAN-to-LAN session by utilizing IPSec/PPTP/L2TP/L2TP over IPSec with AES/DES/3DES for encryption and MD5/SHA-1 for authentication.
You can attach USB storage device to USB port of Vigor2110n to share files. Or, you can use USB printer by connecting it to USB port.
The visual design, with its stylish pleasing lines provides looks good enough to fit into any environment. The Vigor2110n allows you to utilize multimedia applications without compromise of broadband bandwidth!
Draytek Vigor 2110n - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE
Routing Protocol
RIP-2, static IP routing
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Firewall protection, DHCP support, NAT support, VPN support, VLAN support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, MAC address filtering, VPN passthrough, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), Dead Peer Detection (DPD), Wi-Fi Protected Setup (WPS)
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, Wi-Fi Protected Setup, IEEE 802.11n (draft 2.0), UPnP
14.8 cm x 21.6 cm x 5.4 cm
Enclosure Type
Desktop
Wired
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, Wi-Fi Protected Setup, IEEE 802.11n (draft 2.0), UPnP, FCC
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
10 Watt
14.8 cm
21.6 cm
5.4 cm
45 °C
10 - 90%
