DrayTek Vigor 166 VDSL/G.Fast Modem
Quicklinx: G4XRWS00 Mfr#: V166-K
Type: Router
Connection Type: WAN/LAN
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet
Speed: 200Mbps
Rackmount or External: Rack-mountable
£115.05 ex VAT
£138.06 inc VAT
The Vigor 166 is a G.fast and VDSL2 35b modem to Ethernet bridge, connecting G.fast or VDSL to your Ethernet-based Router or Firewall. It provides proven compatibility with UK G.fast and VDSL2 technologies; extensively tested and tuned to provide a robust and reliable DSL connection.
G.fast & VDSL2 35b Capable
Two Gigabit LAN Ports
Add DSL connectivity to any Router
No Setup Needed
Full-Bridge Modem and More
Wall or Shelf Mountable
  • G.fast and VDSL2 35b capable
    Up to 330 Mbps download and 50 Mbps upload with G.fast technology. Can be used with DSL standards, with Vectoring and 35b SuperVectoring.
  • Two Gigabit LAN ports
    Connect two devices to the Vigor 166 with 2 Gigabit (10/100/1000 Mbps) LAN ports. No need to disconnect Ethernet WAN to check connectivity.
  • Add DSL connectivity to any router
    Ideal partner device for DrayTek dual-WAN products or any other vendor's Ethernet WAN firewall. Reports DSL line status on DrayTek Vigor routers.
  • No setup needed
    Works as a modem with most ISPs, straight out of the box. Pre-configured to work with most UK ISPs. Just set the username and password on your router.
  • Full-bridge modem and more
    Two operation modes for the Vigor 166 allow it to operate as a fully bridged DSL to Ethernet modem, or as a mini router with NAT DMZ Host.
  • Wall- or shelf-mountable
    Can be installed securely on a wall or shelf with screw fixings to hold it in place. Mounting kit included.
Draytek Vigor 166 - router - DSL modem - desktop, wall-mountable
Router - DSL modem - 2-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Digital Signaling Protocol
G.fast, VDSL2, ADSL2+
WAN Ports Qty
1
Performance
Firewall throughput: 700 Mbps , NAT throughput with hardware acceleration: 940 Mbps
MTU: 1508 , NAT sessions: 10000
Network / Transport Protocol
PPPoE, PPPoA, RTSP, FTP, PPTP, L2TP, IPSec, IPv4, IPv6, DDNS, DHCP, DHCPv6
Routing Protocol
Static IPv4 routing, static IPv6 routing, IGMP
Remote Management Protocol
HTTP, HTTPS, CLI, Telnet, SSH, TFTP, SNMP 2, SNMP 3, TR-069, TR-104
VoIP Protocols
SIP, H.323
Reset button, NAT support, tagged VLAN, G.INP, UPBO, DPBO, loop diagnostic mode, firmware upgradable, DMZ support, port forwarding, ALG support, VPN passthrough, MAC address filtering, SPI, anti-spoofing protection, DDos attack prevention, DHCP server, DoS attack prevention, IP-MAC binding, URL filtering, IGMP proxy, DHCP client, PPPoE relay, PPPoA relay, PPP, multiple PVC support, IPTV support, Syslog support, NTP client, Diagnostic Function
AC 230V
18.1 cm x 12.5 cm x 4 cm
280 g
Router - 2-port switch (integrated)
Enclosure Type
Wired
Performance
Routing Protocol
Built-in Devices
Led panel
Status Indicators
DSL
Line Properties
Framing Format
ANSI T1.413i2
Communications
DSL modem
Protocols & Specifications
ITU G.993.1, ITU G.993.2, ITU G.997.1, ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3, ITU G.992.5
IP Telephony
VoIP Protocols
SIP, H.323
LAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 - RJ-11
External power adapter
AC 230V
6.6 Watt
1 x RJ-11 phone cable , 1 x network cable
Mounting Kit
Included
OS Provided
No operating system
18.1 cm
12.5 cm
4 cm
280 g
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Speed: 200Mbps
Brand: DrayTek
