The DrayTek Vigor 130 is an ADSL and VDSL modem with an Ethernet connection; it is not a router but a true ADSL/VDSL Ethernet Modem (bridge). The Vigor 130 provides compatibility with all current UK VDSL/ADSL technologies; it has been extensively tested and tuned to provide a robust and reliable DSL connection.
The Vigor 130 is an IPv6 ready compact VDSL2 router with ADSL2/2+ fallback for SOHO and residential broadband access requirement. This compact router is capable to manage the latest VDSL2 feed and backward compatible with the existed ADSL line if the infrastructure is not ready yet. Multi-PVC and multi-VLAN functions make the triple-play deployment with ease. The Vigor 130 can satisfy the different services such as data/video/VoIP/management provided by ISPs by the single VDSL2/ADSL WAN port. And its Gigabit Ethernet LAN port allows devices in the LAN network to get faster data transmission for essential applications.
By providing a PPPoE bridge, the connected device (firewall, router or PC) can log into the Internet (your ISP) directly and have full control over the Internet connection - that makes the Vigor 130 a unique product. You can connect any device to the Vigor 130 which has a PPPoE client facility, which includes PCs, most Ethernet-WAN routers and the Apple Airport/Time Capsuleā¢ products.
Other Ethernet 'modems' may use workarounds to get a public IP address 'through' to your secondary device/client, requiring non-standard operation and complicated dual-stage setup (modem logs in, router routes) but the Vigor 130 provides the secondary device with a real routed IP connection and the ability to fully manage the connection, making setup easy. In most cases, the Vigor 130 needs no setup or configuration - just plug it in and set up your PC or router. All login/ISP details are entered on the connected client device, not the Vigor 130. The actual connection to your ISP is still PPPoA or PPPoE (depending on your ISP and line type).
This transparent bridging method also differs from using a normal ADSL/VDSL router which logs in itself and then uses NAT or multiple public IP addresses to create an onward client connection for your secondary device; that is not IP Address thrifty and can introduce secondary NAT compromises or interference with various protocols/traffic. With the Vigor 130 bridge/modem, you get a true single public IP address (or multiple, if you have them) straight through to your firewall/router.
Line Stats in Vigor Router Interface
A new feature for the Vigor 130 is that, when connected to a Vigor router (Vigor 2830, 2860, 2925 series), the DSL line stats are now displayed in the router's own web interface, alongside any built-in DSL interface stats. As a transparent bridge, it was previously not possible for the DSL line stats to be viewed when the unit was active/online.
- DrayTek Vigor 130 - DSL modem
- DSL modem - Gigabit Ethernet
- Form Factor
- External
- Digital Signaling Protocol
- ADSL, ADSL2, ADSL2+, VDSL2
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.5, ITU G.993.2
- 1-year warranty
- DSL modem
- Form Factor
- External
Modem
- Bus
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Framing Format
- ANSI T1.413
- PPTP, L2TP, NTP, IPSec, PPPoE, PPPoA, FTP, DNS, DDNS
- Remote Management Protocol
- SNMP 1, SNMP 2c, HTTP, HTTPS, TFTP, CLI, TR-069
- Firewall protection, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, E-mail alert, MAC address filtering, IPv6 support, VPN passthrough, URL filtering, firmware upgradable, DDos attack prevention, DHCP server, static IP mode, DNS proxy, IPv4 support, DHCP relay, DHCP client, DNS caching, IGMP proxy
- IEEE 802.1Q, UPnP
- 1 x modem - VDSL2 / ADSL2+ - RJ-11 , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45
- Limited warranty - 1 year
