This product is a magnetic base and extension cable compatible with the LTE antennae included with DrayTek Vigor routers that integrate an LTE modem, such as the Vigor 2620Ln.
This allows your aerials to be positioned to avoid any obstructions or enclosures which are obscuring the router. Adjust the LTE antennas into the optimum location / direction to increase signal strength and throughput.
This is especially useful if the router is installed in a rack inside a comms cabinet because if the aerials are inside the cabinet their signal will be severely impeded. The 1M extension cable allows the aerials to be positioned outside of the cabinet and the magnetic base means that it can be attached to the side of a cabinet if the metal is magnetic.
The magnetic antenna bases are supplied in pairs, purchase a single set to extend the antenna positions for both of the router's antennae. The antenna is not included - that is supplied with your 4G/LTE rouiter.
The LTE antenna aerials supplied with DrayTek LTE modem routers can twist and tilt at their base, which allows for optimum positioning once connected to the ANT-BAS1 base.
- Draytek Magnetic Base & Extension for 4G Aerials - aerial stand
- Product Type
- Aerial stand
- Packaged Quantity
- 2 (specifications are for single item)
- Indoor / Outdoor
- Indoor
- Package Content
- 2 aerial cables (1 m)
- Black
- Packaged Quantity
- Product Type
- Aerial stand
- Indoor / Outdoor
- Indoor
- Package Content
- Enclosure Colour
- Black
- Magnetic base
