DrayTek DrayTek Vigor 2763AC VDSL WLAN Router
Quicklinx: GZH1WS00 Mfr#: V2763AC-K
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11a, IEEE 802.11b, IEEE 802.11n, Gigabit Ethernet + 5 more
Speed: 866Mbps
Rackmount or External: Rack-mountable
  • IEEE 802.11n
More than 50 In Stock
£175.27 ex VAT
£210.32 inc VAT
VDSL and Ethernet Router
The Vigor 2763 is a VDSL or Ethernet WAN router with Gigabit performance, allowing you to make full use of DrayTek's advanced feature set, with Quality of Service, VPN and Content Filtering. Connect the Vigor 2763 to Superfast Fibre with its integrated VDSL modem. Or connect to VirginMedia Cable and Ultrafast FTTP with Ethernet WAN.
Either connection, or a 4G USB modem can be used as the primary or Failover connections, so that if the main Internet connection goes down, the Vigor 2763 can use its backup connections to guarantee reliable Internet access and VPN connectivity.
Powerful SoHo VPN Router
Connecting Remote Sites with LAN to LAN VPN
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
Connect VPNs from behind NAT with DrayTek's VPN Matcher
AC1300 Wireless LAN with Mesh
4 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
DrayDDNS - DrayTek Dynamic DNS Address
Quality of Service with App QoS
  • VDSL and Ethernet router
  • AC1300 wireless with Mesh
    Connect DrayTek VigorAP access points to the router in a wireless Mesh. DrayTek's Self-Optimizing Mesh ensures access points are always connecting through the best path to your router.
  • Packed with features
    Configure DrayTek's rich feature set to fit your network with app level network management, Route Policy, Quality of Service, VPN Matcher, advanced 2-factor security, DrayDDNS and more.
  • Powerful SoHo VPN router
    Connect remote locations with 2 VPN tunnels for Remote Dial-In User Teleworker and Dial-Out LAN to LAN VPN. Up to 150 Mbps IPsec performance, with SSL and OpenVPN support.
  • 4 Gigabit LAN ports with VLANs
    Allows computers, servers and network attached storage to transfer at Gigabit speed. Up to 4 LAN subnets and VLANs allow you to keep guest networks from accessing private network data.
  • VigorACS central management
    DrayTek's powerful VigorACS central management platform allows you to manage, monitor and configure the Vigor 2763, along with all other DrayTek products remotely across multiple locations.
Draytek Vigor 2763ac - wireless router - DSL modem - Wi-Fi 5 - desktop, wall-mountable
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Digital Signaling Protocol
H.323, ADSL, SIP, ADSL2, ADSL2+, VDSL2
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, PPP, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz / 5 GHz
Performance
VPN throughput (256-bit AES IPSec): 200 Mbps , VPN throughput (SSL): 80 Mbps , NAT throughput: 700 Mbps , NAT throughput (with VDSL2): 100 Mbps , NAT throughput with hardware acceleration: 950 Mbps , NAT throughput without hardware acceleration: 700 Mbps , Maximum data rate (2.4 GHz): 400 Mbps , Maximum data rate (5 GHz): 866 Mbps
Priority QoS queues: 4 , Concurrent VPN tunnels: 2 , NAT sessions: 50000 , DHCP pool: 253 , SSIDs per radio: 4 , VLANs supported: 8
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, AAL5, FTP, DHCP, Bonjour, DHCPv6, RTSP, IPv4, IPv6
Routing Protocol
MPOA, static IPv4 routing, static IPv6 routing
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, TR-069, Syslog
VoIP Protocols
H.323, SIP
IGMP snooping, DoS attack prevention, content filtering, port mirroring, E-mail alert, LAN-to-LAN bridging, WMM support, file sharing, TFTP support, ACL support, QoS, DPD, IPSec NAT-T, SMS alert, reset button, DNS server, port triggering, 3G/4G USB Dongle Support, TxBF ready, dual-stream (2x2), IGMP proxy, 802.1x authentication, ToS, automated backup scheduling, MU-MIMO technology, fast leave, Inter-VLAN Routing, L2TP over IPSec, black list, white list, DSCP based ToS, wireless access control, DNSSEC support, PPP, IPTV support, EAPOL, OpenVPN pass-through, Brute Force Protection, SIP ALG, DrayDDNS, WAN Budget, Wi-Fi on/off button, DSL mode, USB backup, ping detect, ARP detect, dynamic DNS, Full Feature-set Hardware Acceleration, 2-Level Administration Privilege, Teleworker-to-LAN bridging, ISP Video support, NAT port redirection, DMZ host, spoofing defence, user-based Time Quota, IP-based Firewall Policy
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, X.509, IEEE 802.11n, UPnP, ITU-T G.993.1, ITU-T G.993.2, ITU-T G.997.1, IEEE 802.11ac Wave 2
AC 100-240 V / DC 12 V
20.7 cm x 13.1 cm x 4.2 cm
450 g
United Kingdom, Ireland
Wireless router - 4-port switch (integrated)
Enclosure Type
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MPPE, SHA-1, WPA, WPA2, 128-bit AES, 192-bit AES, 256-bit AES, IKEv2, WEP, WPS, WPA3, IKEv1, SHA-256
Authentication Method
RADIUS, internal user database, Mobile One Time Password (mOTP)
Wi-Fi Rating
AC1300
IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, X.509, IEEE 802.11n, UPnP, ITU-T G.993.1, ITU-T G.993.2, ITU-T G.997.1, IEEE 802.11ac Wave 2, TOTP
Built-in Devices
Led panel
Status Indicators
WAN, LAN, USB, 5 GHz, 2.4 GHz, QoS
Line Properties
Framing Format
ANSI T1.413i2
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.5 Annex M, ITU G.992.3 Annex M, ITU G.992.5 Annex J, ITU G.992.3 Annex J
Max Transfer Rate
300 Mbps
IP Telephony
VoIP Protocols
H.323, SIP
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A , Antenna: 2 x
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
21 Watt
2 x WiFi aerials
1 x network cable - 2 m
Mounting Kit
Included
OS Provided
No operating system
20.7 cm
13.1 cm
4.2 cm
450 g
10 - 90% (non-condensing)
Standards: IEEE 802.11b
Standards: IEEE 802.11n
Standards: Gigabit Ethernet
Standards: PPP
Standards: IEEE 802.11g
Standards: Ethernet
Standards: Fast Ethernet
Standards: IEEE 802.11ac Wave 2
Speed: 866Mbps
Brand: DrayTek
