DrayTek DrayTek Vigor 2763 VDSL Router
Quicklinx: GZH0WS00 Mfr#: V2763-K
Type: Router
Connection Type: WAN/LAN
Standards: Ethernet, Gigabit Ethernet, Fast Ethernet
Speed: 200Mbps
Rackmount or External: Desktop
42 In Stock
£132.26 ex VAT
£158.71 inc VAT
VDSL and Ethernet Router
The Vigor 2763 is a VDSL or Ethernet WAN router with Gigabit performance, allowing you to make full use of DrayTek's advanced feature set, with Quality of Service, VPN and Content Filtering. Connect the Vigor 2763 to Superfast Fibre with its integrated VDSL modem. Or connect to VirginMedia Cable and Ultrafast FTTP with Ethernet WAN.
Either connection, or a 4G USB modem can be used as the primary or Failover connections, so that if the main Internet connection goes down, the Vigor 2763 can use its backup connections to guarantee reliable Internet access and VPN connectivity.
Powerful SoHo VPN Router
Connecting Remote Sites with LAN to LAN VPN
DrayTek SSL VPN for Dial-In Teleworkers & LAN to LAN
Connect VPNs from behind NAT with DrayTek's VPN Matcher
4 Gigabit LAN Ports with VLANs
Designed for Central Management
Robust & Comprehensive IPv4 / IPv6 Firewall
DrayDDNS - DrayTek Dynamic DNS Address
Quality of Service with App QoS
Multi-Purpose USB Ports
Central AP & Switch Management
  • Enhanced security
    With a suite of authentication methods including Extensible Authentication Protocol (EAP), Mobile One Time Password (mOTP), RADIUS, X.509 certificates, and XAUTH authentication, alongside robust encryption algorithms such as 3DES, AES, DES, IKEv2, MD5, MPPE, SHA-1, SHA-256, and SSL, the Draytek Vigor 2763 ensures your network remains secure against external threats.
  • Comprehensive connectivity
    This router supports a wide range of digital signaling protocols including ADSL2+, VDSL2, and various ITU standards, ensuring compatibility with a broad spectrum of DSL connections. With interfaces for Ethernet 10Base-T/100Base-TX/1000Base-T, VDSL2/ADSL2+, and USB 2.0, it offers versatile connectivity options for different network needs.
  • Advanced networking features
    Featuring 802.1x authentication, Access Control List (ACL) support, DHCP server, DNS server, DoS attack prevention, IPv4 and IPv6 support, Quality of Service (QoS), and VPN support with a throughput of up to 150 Mbps for 256-bit AES IPSec, the Draytek Vigor 2763 is equipped to handle complex networks and ensure smooth operation.
  • Efficient performance
    Achieve high-speed network performance with NAT throughput of up to 940 Mbps with hardware acceleration, and manage VPN connections efficiently with SSL throughput of 100 Mbps and 256-bit AES IPSec throughput of 150 Mbps.
  • Flexible deployment
    Designed for both desktop and wall-mountable setups, this router integrates a 4-port switch and includes features like failover protection, file sharing, and remote firmware upgrade capabilities, making it a versatile choice for various deployment scenarios.
Draytek Vigor 2763 - router - DSL modem - desktop, wall-mountable
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop, wall-mountable
Digital Signaling Protocol
ADSL2+, VDSL2
WAN Ports Qty
1
Performance
VPN throughput (SSL): 100 Mbps , VPN throughput (256-bit AES IPSec): 150 Mbps , NAT throughput with hardware acceleration: 940 Mbps , NAT throughput without hardware acceleration: 400 Mbps
VPN tunnels: 2 , Number of web portal users: 4 , VLANs supported: 8 , LAN Subnet supported: 4 , NAT sessions: 50000
Network / Transport Protocol
FTP, IPSec, L2TP, PPTP, RTSP, OpenVPN, WireGuard, PPPoE, PPPoA, DHCP
Routing Protocol
IGMPv3, IGMPv2, policy-based routing (PBR), static IP routing, static IPv4 routing, static IPv6 routing, RIP-1, RIP-2, MPOA
Remote Management Protocol
Syslog, SNMP 1, SNMP 2c, SNMP 3, HTTP, TFTP, TR-069, HTTPS, Telnet, SSH-2
IPFIX, e-mail notification, SMS alert, ACL support, Brute Force Protection, 2-Level Administration Privilege, remote firmware upgrade, Syslog support, QoS, VoIP support, ToS, DSCP prioritisation, IP address filtering, spoofing defence, DoS attack prevention, content filtering, IP-based Firewall Policy, VPN support, RTSP support, SIP ALG, NAT port redirection, NAT support, port triggering, DMZ host, UPnP, VPN Matcher, IPSec NAT-T, Single-Armed VPN, PSK, PPTP client, PPTP passthrough, L2TP over IPSec, Teleworker-to-LAN bridging, LAN-to-LAN bridging, file sharing, IGMP proxy, IGMP snooping, IGMP fast leave, DNSSEC support, IPv4 support, IPv6 support, Inter-VLAN Routing, DNS server, port mirroring, 802.1x authentication, DHCP server, multiple IP settings, port-based VLAN, DrayDDNS, dynamic DNS, WAN Budget, ARP detect, ping detect, failover protection, VLAN Tagging, VDSL2 profile management, reset button, H.323 Pass-Through
IEEE 802.1p, IEEE 802.1x, IEEE 802.1Q, ITU-T G.998.4, ITU-T G.993.1
DC 12 V 1.3 A
20.7 cm x 13.1 cm x 4.2 cm
450 g
United Kingdom, Ireland
Router - 4-port switch (integrated)
Enclosure Type
Wired
Performance
Routing Protocol
Encryption Algorithm
MPPE, DES, 3DES, AES, MD5, SHA-1, SHA-256, SSL, IKEv2
Authentication Method
X.509 certificates, RADIUS, Mobile One Time Password (mOTP), XAUTH authentication, Extensible Authentication Protocol (EAP)
Communications
DSL modem
ADSL2+, VDSL2
Protocols & Specifications
T1.413 Issue 2, ITU G.992.2 (G.Lite), ITU G.992.1 (G.DMT), ITU G.993.1, ITU G.993.2 Annex A, ITU G.993.2 Annex B, ITU G.993.2 Annex M, ITU G.993.2 Annex Q, ITU G.997.1
LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , USB 2.0: 2 x 4 pin USB Type A , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
DC 12 V
Electric Current Required
1.3 A
14.6 Watt
Wall mounting kit
1 x network cable - 2 m
OS Provided
No operating system
Software Included
VigorACS Management
20.7 cm
13.1 cm
4.2 cm
450 g
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Gigabit Ethernet
Standards: Fast Ethernet
Speed: 200Mbps
Brand: DrayTek
