Draytek As Vigor 2850Vn + Support for VDSL/Infinity or ADSL/2+
Quicklinx: 7VMTWS00 Mfr#: V2850VN
  • IEEE 802.11n
Vigor 2850 Series VDSL/ADSL Router Firewall
The Vigor 2850 is a variant of our Vigor 2830 series with the addition of a built-in interface which supports both ADSL/ADSL2+ and also VDSL lines (such as the BT Infinity™ service) for connectivity up to 50Mb/s. This latest series includes support for professional features such as VLAN tagging, Gigabit Ethernet and WiFi (ess models). The Vigor 2850's secondary WAN interface can be connected to other modems now or later (e.g. a second ADSL, BT Infinity or cable modem etc.).
Packed with features, the Vigor 2850 offers truly comprehensive DSL connetivity and security.
Compatible with all UK variants of ADSL (including ADSLMax, ADSL2+ and Annex M) and VDSL, the Vigor 2850 can also be used for cable-modem and leased line applications using its additional gigabit ethernet WAN port. A four port Gigabit switch on the LAN side provides high speed connectivity for your server or other local PCs, for the highest speed local data transfer. The 4th LAN port operates as a WAN interface in dual-WAN mode.
Security features include content filtering, web application controls and new object based firewall management system.
Robust & Comprehensive Firewall
Security is always taken seriously with DrayTek routers. The firewall protects against attacks including DoS (Denial of Service) attacks, IP-based attacks and access by unauthorised remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The latest ('Version 3') DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organisations. The Vigor 2850 now also allows selective direction firewall rules of LAN to WAN, WAN to LAN or LAN to VPN.
In addition, QoS (Quality of Service Assurance) can now be selectively applied to specific users.
Web Content Filtering
The Content control features of the Vigor 2850 allow you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites with whitelists or blacklists, blocking IM/P2P applications or other potentially harmful or wasteful content. Restrictions can be per user, per PC or univeral. Using DrayTek's GlobalView service, you can block whole categories of web sites (e.g. gambling, adult sites etc.), subject to an annual subscription to the Globalview service, which is continuously updated with new or changed site categorisations or sites which have become compromised (such as infected with Malware). A free 30-day trial is included with your new router.
Triple-WAN Load Balancing & Backup
As well as the primary ADSL (WAN) interface, the Vigor 2850 features two other WAN connections. WAN2 is Ethernet (Gigabit, switchable with LAN4) and WAN3 is a USB port for connection of a 3G modem. WAN2 (Ethernet) can connect to a second ADSL modem (e.g. Vigor 120), a cable modem or any other Ethernet-based Internet feed. The multiple WAN interfaces can be used either for WAN-Backup or load balancing.
WAN-Backup provides contingency (redunancy) in case of your primary ADSL line or ISP suffering temporary outage). Internet Traffic will be temporarily routed via the secondary Internet access. When normal services is restored to your primary ADSL line, all traffic is switch back to that.
If you don't have VDSL/ADSL, the Ethernet WAN port can instead be used as your primary/only Internet connection (using NAT) so the same router can be used for either ADSL or Ethernet Internet connections.
The USB port provides Internet connectivity (main, backup or load balanced) by connecting to a compatible USB modem (or cellphone) for access to the high speed 3G cellular networks from UK providers such as Vodafone, T-Mobile, Orange, 3 and T-Mobile. If you don't have ADSL at all, the USB/3G access method can be used as your primary/only Internet connection, ideal for temporary locations, mobile applications or where broadband access is not available. In addition you can instead connect a compatible analogue modem to use analogue dial-up connections for failover in the event of your broadband failing.
  • Robust & comprehensive firewall
    Security is always taken seriously with DrayTek routers. The firewall protects against attacks including Dos (Denial of Service) attacks, IP-based attacks and access by unauthorized remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organizations. The Vigor 2850 now also allows selective direction firewall rules of LAN to WAN, WAN to LAN or LAN to VPN.
  • Web content filtering
    The content control features of the Vigor 2850 allow you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites with whitelists or blacklists, blocking IM/P2P applications or other potentially harmful or wasteful content. Restrictions can be per user, per PC or universal. Using DrayTek's GlobalView service, you can block whole categories of web sites (e.g. gambling, adult sites etc.), subject to an annual subscription to the Globalview service, which is continuously updated with new or changed site categorizations or sites which have become compromised (such as infected with Malware).
  • Triple-WAN load balancing & backup
Draytek Vigor 2850Vn
Ethernet, Fast Ethernet
Wired
Power adapter - external
45 °C
