DrayTek ANT-2520 10dB Unidirectional Antenna (Single)
Quicklinx: BWBTWS00 Mfr#: ANT-2520
Draytek ANT-2520 is a dual-band indoor directional patch antenna. It is used for normal indoor point-to-point wireless connection applications. ANT-2520 is designed to connect with most wireless devices that use a detachable antenna. Simply unscrew the existing antenna on your device, connect to the Draytek high-gain antenna and enjoy the benefits of wireless network.
Draytek ANT-2520 - antenna
Antenna
6.5 cm x 1.8 cm x 16.5 cm
Plate
Intended For
Wi-Fi
Aerial Placing / Mounting
Indoor
Compatibility
802.11 a/b/g/n/ac
Frequency Range
2.4 - 2.5 GHz, 5.15 - 5.85 GHz
Gain
10 dBi (for 5 GHz), 7.5 dBi (for 2.4 GHz)
Directivity
Directional
1-year warranty
Antenna
6.5 cm
1.8 cm
16.5 cm
Enclosure Colour
Aerial
Plate
Intended For
Wi-Fi
Indoor
Compatibility
802.11 a/b/g/n/ac
Frequency Range
Gain
Directivity
Directional
Voltage Standing Wave Ratio (VSWR)
2.0:1
Horizontal Beamwidth
70° (at 2.4 GHz), 60° (at 5 Ghz)
Vertical Beamwidth
60° (at 2.4 GHz), 30° (at 5 Ghz)
Cabling & Wiring
Connector Provided
1 x RP-SMA male
MIMO technology
Limited warranty - 1 year
