The easy to use, easy to love smartphone
If you want an easy to use smartphone that makes staying connected with family and friends both fun and reassuring, then you'll love the Doro 8100. Conversations are clearer with Doro's optimized sound quality, and our intuitive interface simplifies everything you want to do. Three lenses and a simplified camera menu make it easy to capture spectacular images, including great portraits and low light shots. And two pre-installed apps enable trusted contacts to provide support if you need it. With the TeamViewer app, a person you invite can access and assist you with your phone directly from their own device. And the Response by Doro app, once set up, can send alerts and connect you with family or friends with one press of the assistance button, e.g. if you should fall and need someone's help.
Easy to use with intuitive interface and Google Assistant
Assistance button for sending alerts via the Response by Doro app
Triple camera for stunning photos, day or night
Enhanced connectivity
Equipped with a comprehensive range of connectivity options including 4G LTE, Bluetooth 4.2, NFC, and IEEE 802.11a/b/g/n wireless interfaces, this smartphone ensures you stay connected wherever you go. -
Impressive display
The 6.1-inch HD+ display, with a resolution of 1560 x 720 pixels, offers vivid colors and sharp details for an immersive viewing experience. -
Versatile photography
Featuring a triple rear camera setup with a 13 megapixel main camera, a 2 megapixel macro camera, and a 2 megapixel camera for Bokeh effect, alongside a 5 megapixel front camera, capturing high-quality photos and selfies is effortless. -
Durable design
With an IP54 rating, this device is designed to withstand dust and water splashes, making it a reliable companion for your daily adventures. -
Extended battery life
A 3000 mAh battery provides up to 1380 minutes of talk time or 450 hours of standby time, ensuring your phone keeps up with your busy lifestyle.
 - DORO 8100 - grey - 4G smartphone - 32 GB - GSM
- Product Type
 - 4G smartphone
- Display
 - 1560 x 720 pixels - 6.1"
- Processor
 - Unisoc SC9863
- Memory
 - RAM 2 GB / 32 GB
- Supported Memory Card
 - microSDXC slot - up to 128 GB
- Operating System
 - Android 11 (Go edition)
- Main Camera
 - 13 Megapixel focus: automatic
- Second Camera
 - 2 Megapixel
- Third Camera
 - 2 Megapixel - macro camera
- Front Camera
 - 5 Megapixel
- Service Provider
 - Not specified
- SIM Card
 - Single-SIM - nano SIM
- Wireless Interface
 - NFC, Wi-Fi, Bluetooth
- Connectors
 - 3.5 mm headset jack, USB-C
- Talk Time
 - Up to 1380 minutes
- Standby Time
 - Up to 450 hours
 - Grey
 - 72.99 mm x 9.2 mm x 156 mm
 - 167 g
- Repairability Index
 - 6.7 (out of 10)
- Specific Absorption Rate (SAR)
 - 0.39 W/kg (head) , 1.12 W/kg (body) , 2.84 W/kg (limb)
- Product Type
 - Smartphone
- Form Factor
 - Touch
 - 72.99 mm
 - 9.2 mm
 - 156 mm
 - 167 g
- Body Colour
 - Grey
- SAR Value
 - 1.12 W/kg (body), 0.39 W/kg (head), 2.84 W/kg (limb)
Cellular
- Technology
 - WCDMA (UMTS) / GSM
- Mobile Broadband Generation
 - 4G
- Service Provider
 - Not specified
- Operating System
- Intelligent Assistant
 - Google Assistant
- Navigation
 - GPS, A-GPS, BeiDou
- SIM Card Type
 - Nano SIM
- SIM Card Qty
 - Single-SIM
- Input Device
 - Multi-touch
Communications
- Data Transmission
 - GPRS, HSDPA, HSUPA, FDD-LTE, TDD-LTE
- 2G Band
 - 850 GSM, 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
 - Band 1, Band 2, Band 5, Band 8
- 3G UMTS Frequency
 - 2100, 1900, 850, 900
- 4G LTE Band
 - Band 1, Band 2, Band 3, Band 7, Band 8, Band 20, Band 28, Band 38, Band 40
- 4G LTE Frequency
 - FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600, TDD 2300
 - NFC, IEEE 802.11a/b/g/n, Bluetooth 4.2 LE
Phone Features
- Sensors
 - Accelerometer, proximity sensor, hall sensor, light sensor
- Additional Features
 - SOS button, software updates FOTA (Firmware Over The Air), HD Voice, ICE (In Case of Emergency) function
Media Player
- Supported Digital Audio Standards
 - WAV, AAC, AMR, MP3, FLAC, OGG, APE (Monkey's Audio), M4A, M4R
- Supported Digital Video Standards
 - MKV, RMVB, FLV, AVI, MOV, 3GP, MP4
 - Unisoc
- Processor Number
 - SC9863
- RAM
 - 2 GB
- Internal Memory Capacity
 - 32 GB
- Supported Flash Memory Cards
 - microSDHC, microSD, microSDXC - up to 128 GB
Front Camera
- Sensor Resolution
 - 5 Megapixel
Main Camera
- Sensor Resolution
 - 13 Megapixel
- Focus Adjustment
 - Automatic
- Digital Zoom
 - 4x
- Camera Modes
 - Portrait mode
- Light Source
 - LED flash
 - QR-code scanner
Second Camera
- Sensor Resolution
 - 2 Megapixel
- Special Effects
 - Bokeh effect
Third Camera
- Sensor Resolution
 - 2 Megapixel
- Functions
 - Macro camera
Display
- Diagonal Size
 - 6.1"
- Display Resolution
 - 1560 x 720 pixels
- Display Format
 - HD+
- Connector Type
 - Headset jack - mini-phone 3.5mm , USB Type-C - 24 pin USB-C
- Technology
 - Lithium polymer
- Capacity
 - 3000 mAh
- Talk Time
 - 1380 minutes
- Standby Time
 - 450 hours
- Run Time Details
 - Talk: up to 1380 min , Standby: up to 450 hrs
 - IP54, HEARING AID M3/T3
- Included Accessories
 - Charging stand
Sustainability Information
 - 6.7 (out of 10)
