The Doro 780X targets fragile seniors with severe handling problems. A senior dependent on a robust and extremely easy to use mobile that will help them out throughout the day, with the added peace of mind provided by Doro design and services.
Call the people you rely on in a simple press of a button, and feel even safer thanks to a safety timer function for special situations, alarm button, GPS localization and remote management.
- DORO 780X IUP - black, white - 4G feature phone - 4 GB - GSM
- Product Type
- 4G feature phone
- Display
- 320 x 240 pixels - 2.8"
- LED flashlight
- Processor
- MediaTek MT6731V/ZA
- Memory
- RAM 512 MB / 4 GB
- Supported Memory Card
- microSDXC slot
- Service Provider
- Not specified
- Form Factor
- Bar
- SIM Card
- Dual-SIM - micro SIM
- Wireless Interface
- Wi-Fi, Bluetooth
- Messaging Services
- SMS, MMS
- Connectors
- 3.5 mm headset jack, Micro-USB
- Talk Time
- Up to 480 minutes
- Standby Time
- Up to 330 hours
- Black, white
- 60 mm x 13 mm x 138 mm
- 117 g
- Specific Absorption Rate (SAR)
- 0.785 W/kg (head) , 1.503 W/kg (body) , 2.651 W/kg (limb)
- Product Type
- Feature phone
- Form Factor
- Bar - Yes
- Integrated Components
- LED flashlight
- 60 mm
- 13 mm
- 138 mm
- 117 g
- Body Colour
- Black, white
- SAR Value
- 0.785 W/kg (head), 2.651 W/kg (limb), 1.503 W/kg (body)
Cellular
- Technology
- WCDMA (UMTS) / GSM
- Mobile Broadband Generation
- 4G
- Service Provider
- Not specified
- Navigation
- A-GPS
- SIM Card Type
- Micro SIM
- SIM Card Qty
- Dual-SIM
Messaging & Internet
- SMS, MMS
Communications
- Data Transmission
- GPRS, HSPA+, LTE, VoLTE
- 2G Band
- 900 GSM, 1800 GSM, 1900 GSM
- 3G UMTS Band
- Band 1, Band 2, Band 8
- 3G UMTS Frequency
- 2100, 1900, 900
- 4G LTE Band
- Band 1, Band 3, Band 7, Band 8, Band 20
- 4G LTE Frequency
- FDD 2100, FDD 1800+, FDD 2600, FDD 900, FDD 800 DD
- Wi-Fi, Bluetooth 4.2
Phone Features
- Additional Features
- SOS button, HD Voice, ICE (In Case of Emergency) function, position monitoring, inactivity monitoring, recall alarm request
- MediaTek
- Processor Number
- MT6731V/ZA
- RAM
- 512 MB
- Internal Memory Capacity
- 4 GB
- Supported Flash Memory Cards
- microSDHC, microSD, microSDXC
Display
- Diagonal Size
- 2.8"
- Display Resolution
- 320 x 240 pixels
- Display Format
- QVGA
- Connector Type
- Headset jack - mini-phone 3.5mm , Micro-USB
- Technology
- Lithium Ion
- Capacity
- 1600 mAh
- Talk Time
- 480 minutes
- Standby Time
- 330 hours
- Run Time Details
- Talk: up to 480 min , Standby: up to 330 hrs
- IP54, HAC (Hearing Aid Compatible)
- Included Accessories
- Charging stand
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
GXL3 048568 Condition: Customer return - item has been used and shows signs of use |
£106.35 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
