Doro 6880 4G black 2.8in
Quicklinx: GXL1WS00 Mfr#: 8200
Operating system: Mocor OS
Model: 6880
Mobile Connectivity: 4G
Screen Size: 2.4in
Rear Camera: 2 Megapixel
  • microSDHC
  • microSD
Hurry, only 1 left in stock!
£74.99 ex VAT
£89.98 inc VAT
See caller's name and number right away, and answer with a simple flip. Widely separated, high contrast keys make calling and texting easier, and HD voice enables clearer conversation at both ends of the line. There's also an assistance button for alerting trusted contacts if you should ever need help.
Charging cradle included
  • External display with caller ID and notifications
    See the caller's name and number right away, and answer with a simple flip.
  • Straightforward design
    Widely separated, high-contrast keys make calling and texting easier, and HD voice enables clearer conversation at both ends of the line.
  • Feel more secure with assistance button
    Features an assistance button for alerting trusted contacts if you should ever need help.
DORO 6880 - black, white - 4G feature phone - GSM
4G feature phone
Display
320 x 240 pixels
LED flashlight
Unisoc UMS9117
Supported Memory Card
microSDXC slot - up to 128 GB
Operating System
Mocor OS
Main Camera
2 Megapixel
Service Provider
Not specified
Folder (flip)
SIM Card
Single-SIM - micro SIM
Wireless Interface
Bluetooth
Messaging Services
SMS, MMS
Connectors
3.5 mm headset jack
Talk Time
Up to 420 minutes
Standby Time
Up to 380 hours
Black, white
56 mm x 21 mm x 107 mm
124 g
0.819 W/kg (head) , 1.116 W/kg (body) , 2.358 W/kg (limb)
Feature phone
Folder (flip)
Integrated Components
LED flashlight
56 mm
21 mm
107 mm
124 g
Body Colour
Black, white
SAR Value
1.116 W/kg (body), 0.819 W/kg (head), 2.358 W/kg (limb)
Cellular
WCDMA (UMTS) / GSM
Mobile Broadband Generation
4G
Service Provider
Not specified
Operating System
Mocor OS
SIM Card Type
Micro SIM
SIM Card Qty
Single-SIM
Messaging & Internet
Messaging Services
SMS, MMS
Communications
Data Transmission
GPRS, HSDPA, HSUPA, VoLTE, FDD-LTE, TDD-LTE
2G Band
900 GSM, 1800 GSM, 1900 GSM
3G UMTS Band
Band 1, Band 8
3G UMTS Frequency
2100, 900
4G LTE Band
Band 1, Band 3, Band 7, Band 8, Band 20, Band 28, Band 38
4G LTE Frequency
FDD 2100, FDD 1800+, FDD 2600, FDD 900, FDD 800 DD, FDD 700 APT, TDD 2600
Wireless Interface
Bluetooth 5.0
Phone Features
Additional Features
Software updates FOTA (Firmware Over The Air), HD Voice, ICE (In Case of Emergency) function, Alarm Clock
Unisoc
Processor Number
UMS9117
Supported Flash Memory Cards
microSDHC, microSD, microSDXC - up to 128 GB
Main Camera
Sensor Resolution
2 Megapixel
Light Source
Flash
Display
Display Resolution
320 x 240 pixels
Display Format
QVGA
Connector Type
Headset jack - mini-phone 3.5mm
Lithium Ion
1000 mAh
Talk Time
420 minutes
Standby Time
380 hours
Run Time Details
Talk: up to 420 min , Standby: up to 380 hrs
HEARING AID M4/T4
Power adapter, charging cradle
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: GXL1 050966
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £42.72
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Model: 6880
Screen Size: 2.4in
Brand: Doro
Stock Status: Used Stock
