DJI Zenmuse P1 (ENT)
Quicklinx: HW8LWS00 Mfr#: CP.ZM.00000136.01#EDU
The Zenmuse P1 integrates a full-frame sensor with interchangeable fixed-focus lenses on a 3-axis stabilized gimbal. Designed for photogrammetry flight missions, it takes efficiency and accuracy to a whole new level.
  • Extraordinary efficiency
    The P1 includes a full-frame, low-noise high-sensitivity sensor that can take a photo every 0.7 s during the flight, and covering 3 km2 in a single flight.
  • Remarkable accuracy
    Equipped with a global mechanical shutter and the all-new TimeSync 2.0 system, which synchronizes time across modules at the microsecond level, the Zenmuse P1 lets users capture centimeter-accurate data combined with the real-time position and orientation compensation technology.
  • Robust versatility
    Create 2D, 3D, and detailed models thanks to the integrated 3-axis gimbal that can be outfitted with 24/35/50mm lenses and the Smart Oblique Capture feature.
  • Smart oblique capture
    Cover 7.5 km2 in a single workday with the P1. Elevate the efficiency of your oblique photography mission using Smart Oblique Capture, where the gimbal automatically rotates to take photos at the different angles needed. Only photos essential to the reconstruction will be taken at the edge of the flight area, increasing the efficiency of post processing by 20% to 50%.
  • Fieldwork report
    Verify data quality immediately post-flight by checking the position data and number of the images acquired, as well as RTK status and positioning accuracy.
DJI Zenmuse P1 - aerial camera 35mm f/2.8 lens
Aerial camera
Lens Included
35mm f/2.8 lens
Memory Card Slot
SD card
Sensor Resolution
45.0 MP
Effective Sensor Resolution
Photo: 45.0 MP
Max Video Resolution
3840 x 2160
Lens System
35 mm f/2.8 DL LS ASPH
Min Focus Distance
85 cm
Image Stabiliser
Optical (3-axis gimbal)
16.6 cm x 12.9 cm x 19.8 cm
800 g
Aerial camera
Lens Included
35mm f/2.8 lens
Camcorder Sensor Resolution
45.0 MP
Effective Photo Resolution
45.0 MP
Optical Sensor Size
Full Frame (35.9 x 24.0 mm)
Frame Rate (Max Resolution)
60 fps
ISO (Max)
25600
Image Stabiliser
Built-in Optical Image Stabiliser
Digital Video Format
MPEG-4, MOV
3840 x 2160
Exposure & White Balance
Light Sensitivity
ISO 100-25600
Max Shutter Speed
1/8000 sec
Min Shutter Speed
1 sec
Lens System
35 f/2.8 DL LS ASPH
Min Focus Distance
85 cm
Max View Angle
63.5 degree(s)
Lens Construction
8 groups / 9 elements
Filter Size
46 mm
Lens Mounting Type
DL
Aspherical lens
Protection
IP4X
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
Memory Card Max Supported Size
512 GB
Image Storage
8192 x 5460
Video Capture
3840 x 2160 p - 60 fps , 1920 x 1080 p - 60 fps
DJI Care Enterprise Basic
16.6 cm
12.9 cm
19.8 cm
800 g
-20 °C
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
