DJI Phantom 4 Pro+ 4K 60fps 20MP Camera Quadcopter Drone
Quicklinx: CYLWWS00 Mfr#: CP.PT.000548
An uprated camera is equipped with a 1-inch 20-megapixel sensor capable of shooting 4K/60fps video and Burst Mode stills at 14 fps. The adoption of titanium alloy and magnesium alloy construction increases the rigidity of the airframe and reduces weight, making the Phantom 4 Pro similar in weight to the Phantom 4. The FlightAutonomy system adds dual rear vision sensors and infrared sensing systems for a total of 5-direction of obstacle sensing and 4-direction of obstacle avoidance.
  • Camera with 20MP sensor
    The onboard camera has been redesigned to use a 20-megapixel CMOS sensor. A custom engineered lens made up of eight elements is arranged in seven groups, it is the first DJI camera to use a mechanical aperture that eliminates rolling shutter distortion that can occur when taking images of fast moving subjects or when flying at high speed and a mechanical focus. In effect, it is as powerful as many traditional ground cameras. Advanced sensors and processors ensure everything is captured with more image detail and the image data needed for advanced post-production.
  • Five directions of obstacle sensing
    FlightAutonomy is expanded with an additional set of high-resolution stereo vision sensors placed at the rear in addition to the pair placed at the front as well as infrared sensing systems placed on the left and right sides. This network creates a total of five directions of obstacle sensing and four directions of obstacle avoidance, protecting the Phantom 4 Pro from more obstacles and giving filmmakers the confidence to capture more complex images.
  • Remote controller with built-in screen
    The Phantom 4 Pro controller integrates an upgraded Lightbridge HD video transmission system that adds 5.8 GHz transmission support. The ability to choose between 2.4Ghz and 5.8Ghz allows pilots to cut through interference and eliminates image lag caused when flying in an area with extensive 2.4Ghz frequency use. An integrated screen makes bright, vivid colors easily visible in direct sunlight.
  • Return to home
    In its upgraded return to home mode, the Phantom 4 Pro can automatically choose the perfect route to return home depending on environmental conditions. It records its route as it flies, allowing it to return along the same route avoiding obstacles if the control signal is disconnected.
  • Gesture mode
    Using gesture mode, selfies can be captured easily using a few gestures without the remote controller. Advanced computer vision technology allows the Phantom 4 Pro to take instructions through gestures. The subject simply lifts their arms when facing the camera and the aircraft will recognize this movement by locking on and placing the subject in the center of the frame.
DJI Phantom 4 Pro+ - quadcopter
Quadcopter
Included Items
Micro-USB cable, battery charger, power cable, carrying case, 4 propellers, 16 GB MicroSD card, gimbal clamp, intelligent flight battery, USB OTG cable, remote controller with built-in display
Category
Vehicles - drones
Compatibility
iPhone, iPad, Android phone
Camera
Included - 20 Megapixel
Navigation
GPS/GLONASS receiver
USB, Wi-Fi
White
1.388 kg
Quadcopter
Included Items
Category
Vehicles - drones
Compatibility
Size
350 mm
Remote Control
Yes - 5.8 GHz - max operating distance: 7 km
Power Source
Supported Flash Memory Cards
microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card, microSD Class 10 up to 128 GB
Obstacle avoidance system
RC Vehicle
Take-Off Weight
1388 g
Vertical Hovering Accuracy
+/- 0.1 metres
Horizontal Hovering Accuracy
+/- 0.3 metres
Max Angular Velocity
250° per second
Max Tilt Angle
42°
Max Horizontal Velocity
20 metres per second
Max Ascent Speed
6 metres per second
Max Descent Speed
4 metres per second
Max Wind Speed Resistance
10 metres per second
Navigation
USB, Wi-Fi
Wi-Fi Bands
2.4 GHz, 5 GHz
Gimbal
Control Accuracy
0.02°
Control Angle Range
-90 to 30°
Max Speed
+/- 90° per second
Digital Camera
Sensor Resolution
20 Megapixel
Image Sensor Type
CMOS
Capture Formats
H.264, MP4, MOV, H.265
Video Recorder Resolutions
1280 x 720 (720p), 1920 x 1080 (1080p), 3840 x 2160 (2160p), 4096 x 2160, 2720 x 1530
Frame Rate
60 frames per second
Still Image Formats
JPEG, RAW, DNG
Still Image Resolutions
5472 x 3648, 4864 x 3648, 5472 x 3078
Max View Angle
84 degree(s)
Supported Battery Configurations
4S
Lithium polymer
Voltage
15.2 V
5870 mAh
Run Time
Up to 30 min
Controller Battery
1 x 2S
White
1.388 kg
