DJI Phantom 4 Pro - Quadcopter Drone
Quicklinx: CYLZWS00 Mfr#: CP.PT.000487
Marketing description is not available.
DJI Phantom 4 Pro - quadcopter
Quadcopter
Included Items
Micro-USB cable, battery charger, power cable, carrying case, remote controller, 4 propellers, 16 GB MicroSD card, gimbal clamp, intelligent flight battery, USB OTG cable
Category
Vehicles - drones
Compatibility
iPhone, iPad, Android phone
Camera
Included - 20 Megapixel
USB
1.388 kg
Quadcopter
Included Items
Category
Vehicles - drones
Compatibility
Size
350 mm
Remote Control
Yes - 5.8 GHz - max operating distance: 7 km
Power Source
Supported Flash Memory Cards
microSDHC UHS-I Memory Card, microSDXC UHS Class 3 Memory Card, microSDXC UHS-I Memory Card, microSDHC UHS Class 3 Memory Card, microSD Class 10 up to 128 GB
Obstacle avoidance system
RC Vehicle
Take-Off Weight
1388 g
Vertical Hovering Accuracy
+/- 0.1 metres
Horizontal Hovering Accuracy
+/- 0.3 metres
Max Angular Velocity
250° per second
Max Tilt Angle
42°
USB
Wi-Fi Bands
2.4 GHz, 5 GHz
Gimbal
Control Accuracy
0.02°
Control Angle Range
-90 to 30°
Max Speed
+/- 90° per second
Digital Camera
Sensor Resolution
20 Megapixel
Capture Formats
H.264, MP4, MOV, H.265
Video Recorder Resolutions
1280 x 720 (720p), 1920 x 1080 (1080p), 3840 x 2160 (2160p), 4096 x 2160, 2720 x 1530
Frame Rate
30 frames per second
Still Image Formats
JPEG, RAW, DNG
Supported Battery Configurations
4S
Lithium polymer
Voltage
15.2 V
5870 mAh
Run Time
Up to 30 min
Controller Battery
1 x 2S
1.388 kg
