DJI Phantom 4 Advanced+ 4K 60fps 20MP Camera Quadcopter Drone
Quicklinx: CYM1WS00 Mfr#: CP.PT.000697
Phantom 4 ADVANCED
VISIONARY INTELLIGENCE.
ELEVATED IMAGINATION.
CAMERA WITH 1-INCH 20MP SENSOR
The onboard camera is equipped with a 1-inch 20-megapixel CMOS sensor. A mechanical shutter is used to eliminate rolling shutter distortion, which can occur when taking images of fast-moving subjects or when flying at high speeds. In effect, it is as powerful as many professional cameras. More powerful video processing supports H.264 4K videos at 60 fps or H.265 4K at 30 fps, both with a 100Mbps bitrate. Excellent optical performance, sensors, and processors ensure everything is captured with high dynamic range and more image detail needed for advanced post-production.
The Phantom 4 Advanced's camera system improves upon everything that made the original Phantom 4 so iconic. Every aspect has been significantly upgraded, including the sensor size, resolution, and image processing system, making it the most powerful Phantom to date. Users can also adjust aperture from f2.8-11 for more versatile imaging.
Sensor size is more important to image quality than the number of pixels because a larger sensor captures more information in every pixel, improving dynamic range, signal-to-noise ratio, and low light performance. The 1-inch 20-megapixel CMOS sensor in the Phantom 4 Advanced is almost four times the size of the Phantom 4's 1/2.3in sensor. It uses larger pixels and has a maximum ISO of 12800 as well as increased contrast. It is good enough for images to be used immediately, while also capturing enough detail for advanced post-processing.
Professional 4K Video
An enhanced video processing system allows video to be captured in cinema and production optimized DCI 4K/60 (4096 x 2160/60 fps) at a bitrate of 100 Mbps, enabling you to get high-resolution slow motion shots. The Phantom 4 Advanced also supports the H.265 video codec (maximum resolution 4096X2160/30 fps). For a given bitrate, H.265 doubles the amount of image processing as H.264, resulting in significantly enhanced image quality. Recording in high dynamic range D-log makes the most of image data for color grading.
5 Vision Sensors
Equipped with DJI’s FlightAutonomy system made up of five vision sensors, dual-band satellite positioning (GPS and GLONASS), ultrasonic rangefinders, and redundant sensors, the Phantom 4 Advanced can hover precisely in places without GPS and navigate complex environments. The dual forward vision sensors can see as far as 30 m out in front, enable auto brake, and hover or detour in front of obstacles within a 15-meter range.
REMOTE CONTROLLER WITH BUILT-IN SCREEN
The Phantom 4 Advanced+ comes equipped with the upgraded Lightbridge HD video transmission system, which has a maximum video transmission range of 4.3 mi (7 km) (1). A 5.5-inch 1080p screen integrated with the Phantom 4 Advanced+ offers 1000 cd/m2 of brightness, more than twice as bright as conventional smart devices, enabling clear visibility in direct sunlight. With a five-hour battery life, the Phantom 4 Advanced+ is a powerful aerial imaging solution. The built-in DJI GO 4 app allows you to live stream, edit, and share your aerial videos and photos instantly.
(1)Unobstructed, free of interference, when FCC compliant.
Specs
Aircraft
Weight (Battery & Propellers Included) - 1368 g
Diagonal Size (Propellers Excluded) - 350 mm
Max Ascent Speed:
S-mode: 6 m/s
P-mode:5 m/s
Max Descent Speed:
S-mode:4 m/s
P-mode:3 m/s
Max Speed:
S-mode: 45 mph (72 kph)
A-mode: 36 mph (58 kph)
P-mode: 31 mph (50 kph)
Max Tilt Angle:
S-mode: 42°
A-mode: 35°
P-mode: 25°
Max Angular Speed:
S-mode: 250°/s
A-mode: 150°/s
Max Service Ceiling Above Sea Level - 19685 feet (6000 m)
Max Wind Speed Resistance - 10 m/s
Max Flight Time - Approx. 30 minutes
Operating Temperature Range - 32° to 104°F (0° to 40°C)
Satellite Positioning Systems - GPS/GLONASS
Hover Accuracy Range:
Vertical:
±0.1 m (with Vision Positioning)
±0.5 m (with GPS Positioning)
Horizontal:
±0.3 m (with Vision Positioning)
±1.5 m (with GPS Positioning)
Drone Code
Please take a moment to familiarise yourself with the Drone code before flying your drone. When you fly a drone in the UK it is your responsibility to be aware of the rules that are in place to keep everyone safe. Follow these simple steps to make sure you are flying safely and legally.
On 30 July the UK drone rules changed to make it against the law to fly above 400ft (120m) and to make it against the law to fly your drone within 1km of an airport or airfield boundary.
  1. Always keep your drone in sight
  2. Stay below 400ft (120m) to comply with the dronecode
  3. Every time you fly your drone you must follow the manufacturer’s instructions
  4. Keep the right distance from people and property – People & Properties 150ft (50m), Crowds and built up areas 500ft (150m)
  5. You are legally responsible for each flight
  6. Stay well away from aircraft, airports and airfields. If your drone endangers the safety of an aircraft it is a criminal offence.
For more information visit: https://dronesafe.uk/drone-code/
