DJI Osmo Pocket 3 Creator Combo
Quicklinx: HNZTWS00 Mfr#: CP.OS.00000302.02
FOR MOVING MOMENTS
The all-new DJI Osmo Pocket 3 features a powerful 1-inch CMOS sensor that puts detail-rich imaging right in the palm of you hand, with 4K/120fps video for breathtaking slow motion, 10-bit D-Log M and HLG for professional-level true-to-life colours and improved low-light performance. Featuring a 2-inch rotatable touchscreen and full-pixel fast focusing, go horizontal or vertical for more precise awareness and control. With three-axis mechanical stabilisation and ActiveTrack 6.0 for smooth stabilised, tracking footage with multiple follow modes and stabilisation levels to get the best out of your footage. Pocket 3 adopts a built-in three-mic array to reduce wind noise and record omnidirectional stereo sound and with the built-in Wi-Fi & Bluetooth module you can connect to two DJI Mic 2 Transmitters to give you ultra-clear audio for vlogging, interviews, livestreams and more. With a improved battery life of 116minutes of 4K/60fps or 166minutes of 1080p/24fps gives you more time to get the shots you love. DJI Osmo Pocket 3 ready for any moving moment.
DJI Osmo Pocket 3 - Creator Combo - action camera
Action camera - 4K
Memory Card Slot
microSD card
Wireless Interface
Wi-Fi, Bluetooth
Sensor Resolution
9.4 MP
Effective Sensor Resolution
Photo: 9.4 MP
Max Video Resolution
3840 x 2160
Lens System
Wide-angle lens f/2.0
Focus Adjustment
Fixed focus
Min Focus Distance
20.1 cm
Image Stabiliser
Optical (3-axis gimbal)
Display
LCD display - 2"
Supported Battery
1300 mAh (included)
13.97 cm x 3.35 cm x 4.22 cm
179 g
Action camera - 4K
Camcorder Sensor Resolution
9.4 MP
Sensor Qty
1 CMOS
Effective Photo Resolution
9.4 MP
Optical Sensor Type
CMOS
Optical Sensor Size
1"
Frame Rate (Max Resolution)
60 fps
ISO (Max)
16000
Extended ISO (Max)
16000
Extended ISO (Min)
50
Image Stabiliser
Built-in Optical Image Stabiliser
Supported Host Device Platform
Android, iOS
Digital Video Format
MP4, H.264, AVC, H.265, HEVC
Image Recording Format
JPEG, DNG (RAW)
3840 x 2160
Audio Signal Format
AAC
IEEE 802.11a/b/g/n/ac, Bluetooth 5.2 LE
Connectivity Features
IP streaming
Exposure & White Balance
Light Sensitivity
ISO 50-6400
Max Shutter Speed
1/8000 sec
Min Shutter Speed
1 sec
Lens System
Wide-angle lens f/2.0 - wide angle
Focal Length Equivalent to 35mm Camera
20mm
Focus Adjustment
Fixed focus
Min Focus Distance
20.1 cm
Max View Angle
180 degree(s)
Additional Features
Self-Timer Delay
3sec, 5 sec, 7 sec
Additional Features
Built-in 3 microphones, interval shooting mode
Action Camera Features
Hyperlapse recording, Time-Lapse recording, motionlapse recording
Display
2" LCD display
Resolution
314 x 556 pixels
Display Form Factor
Built-in
Touch Screen
Connector Type
USB
Software
Software
DJI Mimo App
USB-C to USB-C PD cable, protective cover, wrist strap, handle with 1/4" thread, wide-angle lens, wireless microphone transmitter, microphone windscreen, microphone clip magnet, battery handle, mini tripod, carrying bag
Battery Type
Lithium polymer - manufacturer-specific
Run Time (Up To)
166 min
Details
1300 mAh (included)
Battery Life Details
Video recording - 166 minutes
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card, microSDHC UHS-II Memory Card, microSDXC UHS-II Memory Card
Memory Card Max Supported Size
512 GB
Video Capture
MPEG-4 - 3840 x 2160 - 24 - 60 fps , MPEG-4 - 2688 x 1512 - 24 - 60 fps , MPEG-4 - 1920 x 1080 - 24 - 60 fps , MPEG-4 - 3072 x 3072 - 24 - 60 fps , MPEG-4 - 2160 x 2160 - 24 - 60 fps , MPEG-4 - 1080 x 1080 - 24 - 60 fps , MPEG-4 - 3072 x 1728 - 24 - 60 fps , MPEG-4 - 2688 x 1512 - 24 - 60 fps , MPEG-4 - 1080 x 1920 - 24 - 60 fps , 3840 x 2160 - 120 fps , 3840 x 2160 - 100 fps , 2688 x 1512 - 120 fps , 1920 x 1080 - 240 fps , 1920 x 1080 - 120 fps
13.97 cm
3.35 cm
4.22 cm
179 g
15.8 cm x 9.91 cm x 4.57 cm / 345 g
