Compact & Portable
Carry your Osmo Mobile 6 on exciting adventures. The compact and foldable design is easy to pack, and with the quick-release magnetic phone clamp, you can get going without the hassle of removing your phone case.
Quick Launch
Osmo Mobile 6 automatically powers on as soon as you unfold it. Snap in a paired smartphone, and the DJI Mimo app pops up automatically, allowing you to start shooting as soon as inspiration strikes.
3-Axis Stabilization
With 3-axis stabilization, capture smooth, lossless, on-the-move creations that impress and wow. Osmo Mobile 6 integrates DJI's advanced stabilization technology that puts strong, stable, shake-free results at your fingertips.
Active Track 5.0
The improved version allows the front camera to track subjects that turn to the side or spin. During camping, traveling, or street shooting, the gimbal automatically keeps the subject dead center to make your footage more story-like.
- DJI Osmo Mobile 6 motorised handheld stabiliser - wireless - Bluetooth
- Product Type
- Motorised handheld stabiliser
- 9.9 cm x 11.15 cm x 27.6 cm
- 309 g
- Slate grey
- Wireless Interface
- Bluetooth 5.1
- Head Type
- Gimbal
- Max Supported Weight
- 290 g
- Product Type
- Connectivity Technology
- Wireless
- Bluetooth 5.1
- 9.9 cm
- 11.15 cm
- 27.6 cm
- 309 g
- Slate grey
Tripod
- Quick Release System
- 290 g
- Supported Devices
- Mobile phone
- Supported Devices Dimensions
- 67 - 84 mm (width), 6.9 - 10 mm (thickness)
- Foldable
- Tracking function, battery operated, 3-axis stabilisation, anti-slip coating, time-lapse recording, magnetic quick-release, gesture control, built-in extension rod, DynamicZoom mode, ActiveTrack 5.0, quick lauch, spin shot, tilt locked, FPV mode, panorama
Head
- Head Type
- Gimbal
- Head Positioning
- 3-way
- Max Speed
- 120° per second
- Pan (degrees)
- -161.64/+173.79
- Tilt (degrees)
- -101.64/+78.55
- Roll (degrees)
- -120.3/+211.97
- Tripod Mount
- 1/4"-20 screw
- Rechargeable Battery
- Rechargeable
- Technology
- Lithium polymer
- Capacity
- 1000 mAh
- Run Time (Up To)
- 6.4 hrs
- Recharge Time
- 1.4 hours
Kit Content
- Kit Content
- (1) x USB cable , (1) x pouch , (1) x magnetic phone clamp , (1) x grip tripod
Dimensions & Weight Details
- Dimensions & Weight Details
- Folded - 4.4 cm x 8.45 mm x 18.9 mm - 309 g , Magnetic phone clamp - 31 g
