DJI Osmo Mobile 6
DJI Osmo Mobile 6
Quicklinx: HNZSWS00 Mfr#: CP.OS.00000213.01
Type: [N/A]
Hurry, only 3 left in stock!
£112.50 ex VAT
£135.00 inc VAT
Compact & Portable
Carry your Osmo Mobile 6 on exciting adventures. The compact and foldable design is easy to pack, and with the quick-release magnetic phone clamp, you can get going without the hassle of removing your phone case.
Quick Launch
Osmo Mobile 6 automatically powers on as soon as you unfold it. Snap in a paired smartphone, and the DJI Mimo app pops up automatically, allowing you to start shooting as soon as inspiration strikes.
3-Axis Stabilization
With 3-axis stabilization, capture smooth, lossless, on-the-move creations that impress and wow. Osmo Mobile 6 integrates DJI's advanced stabilization technology that puts strong, stable, shake-free results at your fingertips.
Active Track 5.0
The improved version allows the front camera to track subjects that turn to the side or spin. During camping, traveling, or street shooting, the gimbal automatically keeps the subject dead center to make your footage more story-like.
DJI Osmo Mobile 6 motorised handheld stabiliser - wireless - Bluetooth
Motorised handheld stabiliser
9.9 cm x 11.15 cm x 27.6 cm
309 g
Slate grey
Wireless Interface
Bluetooth 5.1
Head Type
Gimbal
Max Supported Weight
290 g
Wireless
Wireless Interface
Bluetooth 5.1
9.9 cm
11.15 cm
27.6 cm
309 g
Slate grey
Tripod
Quick Release System
290 g
Supported Devices
Mobile phone
Supported Devices Dimensions
67 - 84 mm (width), 6.9 - 10 mm (thickness)
Foldable
Tracking function, battery operated, 3-axis stabilisation, anti-slip coating, time-lapse recording, magnetic quick-release, gesture control, built-in extension rod, DynamicZoom mode, ActiveTrack 5.0, quick lauch, spin shot, tilt locked, FPV mode, panorama
Head
Head Type
Gimbal
Head Positioning
3-way
Max Speed
120° per second
Pan (degrees)
-161.64/+173.79
Tilt (degrees)
-101.64/+78.55
Roll (degrees)
-120.3/+211.97
Tripod Mount
1/4"-20 screw
Rechargeable Battery
Rechargeable
Lithium polymer
1000 mAh
Run Time (Up To)
6.4 hrs
Recharge Time
1.4 hours
Kit Content
Kit Content
(1) x USB cable , (1) x pouch , (1) x magnetic phone clamp , (1) x grip tripod
Dimensions & Weight Details
Folded - 4.4 cm x 8.45 mm x 18.9 mm - 309 g , Magnetic phone clamp - 31 g
Type: [N/A]
Brand: DJI
