DJI Osmo+ 4K Handheld with Zoom Camera
Quicklinx: CYL7WS00 Mfr#: CP.ZM.000428
Get closer to your subjects than ever before with the DJI Osmo+, DJI's first handheld gimbal with an integrated zoom camera. A 7× zoom, consisting of 3.5× optical and 2× digital lossless zoom, gives it a focal length ranging from 22 mm to 77 mm without sacrificing HD quality. This gives you more control over your composition than ever before.
  • Motion timelapse
    Osmo+ helps you record the passage of time more easily than ever. Just mark where you want the camera movement to start and end, and tap 'Start' to create phenomenal moving timelapses without additional equipment.
  • Advanced stabilization
    The Osmo+ builds on the advanced stabilization technology introduced with the Osmo to keep the camera flat no matter how you move it, whether you are live streaming or shooting your first film, and has been optimized for ultimate stability during stills capture.
  • Moving selfies
    A focal distance that starts from just 0.5 meters means you are perfectly in focus when shooting an action selfie. Just triple tap the trigger button to enter Selfie Mode and start shooting.
  • Detailed panorama
    Take big, detailed landscape photos you will want to frame using only your smartphone and the Osmo+. Its Panorama function automatically captures and blends 9 separate photos together to create one stunning photo.
  • Long exposure
    Take long exposure shots with absolute crispness and sharpness, even without a tripod. The stabilization system in the Osmo+ keeps the camera totally still so you can freehand capture long exposures.
  • Powerful camera
    Shoot crisp 4K/30fps video and 1080p/100fps for slow motion video, with enhanced sound capture through the included FlexiMic or capture 12 megapixel stills in Adobe DNG RAW for more editing freedom.
DJI Osmo+ - action camera
Action camera - 4K
Action Camera Type
Mountable
Memory Card Slot
microSD card
Wireless Interface
Wireless LAN
Sensor Resolution
12.76 MP
Effective Sensor Resolution
Photo: 12.4 MP
Max Video Resolution
4096 x 2160
Lens System
3.5x zoom - 4 - 14 mm - f/2.8-5.2
Min Focus Distance
50 cm
Digital Zoom
2x
Image Stabiliser
Optical (3-axis gimbal)
Supported Battery
Li-Polymer rechargeable battery - 1225 mAh (included)
Action camera - 4K
Camcorder Sensor Resolution
12.76 MP
Sensor Qty
1 CMOS
Effective Photo Resolution
12.4 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
25 fps
ISO (Max)
3200
Optical Zoom
3.5x
Digital Zoom
2x
Image Stabiliser
Digital Video Format
H.264
Image Recording Format
JPEG, DNG (RAW)
4096 x 2160
Audio Signal Format
AAC
Wireless LAN
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 100-1600, ISO 100-3200
Exposure Modes
Automatic
White Balance
Automatic
Max Shutter Speed
1/8000 sec
Min Shutter Speed
30 sec
Auto Exposure Bracketing
3, 5 steps in 2/3 EV step
Lens System
Focal Length Equivalent to 35mm Camera
22 - 77mm
Min Focus Distance
50 cm
Max View Angle
92 degree(s)
Additional Features
Additional Features
Panorama Capture, motion Time-Lapse recording
Action Camera Features
Camera Type
Mountable
Battery charger, shoulder strap, microphone, storage case, wrist strap, 3-axis gimbal, rosette protection cup, mobile phone holder
Battery Type
Lithium polymer - manufacturer-specific
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Card
Memory Card
16 GB microSDHC
Memory Card Included
Memory Card Max Supported Size
64 GB
Image Storage
4000 x 3000
Video Capture
4096 x 2160 - 25 fps , 4096 x 2160 - 24 fps , 3840 x 2160 - 25 fps , 3840 x 2160 - 24 fps , 3840 x 2160 - 30 fps , 2704 x 1520 - 25 fps , 2704 x 1520 - 24 fps , 2704 x 1520 - 30 fps , 1920 x 1080 - 100 fps , 1920 x 1080 - 60 fps , 1920 x 1080 - 50 fps , 1920 x 1080 - 48 fps , 1920 x 1080 - 30 fps , 1920 x 1080 - 25 fps , 1920 x 1080 - 24 fps
