Go Big With Mini
DJI Mini 4 Pro is our most advanced mini-camera drone to date. [4] It integrates powerful imaging capabilities, omnidirectional obstacle sensing, ActiveTrack 360° with the new Trace Mode, and 20km FHD video transmission, bringing even more things to love for pros and beginners alike.
Take it Easy
Take off whenever the inspiration strikes. Weighing less than 249 g, Mini 4 Pro was designed for convenience on the go, [1] and the drone's weight means there's no need for training or registration in a majority of countries and regions.
- DJI Mini 4 Pro Fly More Combo (DJI RC 2) - drone
- Product Type
- Drone
- Included Items
- Screwdriver, USB-C cable, shoulder bag, charging hub, gimbal protector, 3 intelligent flight batteries, 3 pairs of propellers, propeller holder, 18 screws, USB-C PD cable, RC 2 remote controller
- Category
- Vehicles - parts and accessories, vehicles - drones
- Remote Control
- Power Source
- Battery
- Outdoor
- Supported Flash Memory Cards
- microSDHC, microSDXC up to 512 GB
RC Vehicle
- Flash Memory
- 2 GB
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.1 metres
- Max Horizontal Velocity
- 16 metres per second
- Max Ascent Speed
- 5 metres per second
- Max Descent Speed
- Max Wind Speed Resistance
- 10.7 metres per second
- Navigation
- GPS/Galileo/BeiDou
- Interface
- USB
Gimbal
- Control Accuracy
- 0.01°
- Control Angle Range
- -135 to 80° (pitch), -135 to 45° (roll), +/- 30° (yaw)
- Max Speed
- 100° per second (tilt)
Digital Camera
- Sensor Resolution
- 48 Megapixel
- Image Sensor Type
- CMOS
- Digital Zoom
- 4
- Capture Formats
- MP4 (MPEG-4 AVC/H.264, HEVC/H.265)
- Video Recorder Resolutions
- 1920 x 1080 (1080p) at 200 fps, 3840 x 2160 (4K) at 100 fps
- Still Image Formats
- JPEG, RAW, DNG
- Rechargeable Battery
- Rechargeable
- Technology
- Lithium Ion
- Voltage
- 7.32 V
- Capacity
- 2590 mAh
- Run Time
- Up to 34 min
Choking Hazard Warnings
- Dimensions & Weight Details
- Folded - 9.4 cm x 14.8 cm x 6.4 cm , Unfolded - 29.8 cm x 37.3 cm x 10.1 cm , Battery - 77.9 g
- -10 °C
- 40 °C
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HGS5 049164 Condition: Customer return - item has been opened but is in excellent condition |
£670.37 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
