DJI Mavic Pro - 4K Quadcopter Drone
Quicklinx: CYL8WS00 Mfr#: CP.PT.000499
The DJI Mavic Pro is a small yet powerful drone that turns the sky into your creative canvas easily and without worry, helping you make every moment an aerial moment. Its compact size hides a high degree of complexity that makes it one of DJI’s most sophisticated flying cameras ever. 24 high-performance computing cores, an all-new transmission system with a 4.3mi (7km) range, 5 vision sensors, and a 4K camera stabilized by a 3-axis mechanical gimbal, are at your command with just a push of your thumb or a tap of your finger.
Fly further
Inside the Mavic’s pocket-sized remote controller is DJI’s brand new OcuSync transmission technology, with a range of 4.3mi (7km), HD 720p long range and Full HD 1080p short range video streaming.
No bumps and scrapes
An unprotected drone could hit obstacles during long distance flight or when descending from an inadequate height in Return to Home mode. The Mavic uses FlightAutonomy technology to sense obstacles up to 49ft (15m) away and allows the Mavic to bypass them or brake to hover, reducing accidents.
Precision Hover
Satellite positioning can only help a drone hover in an unobstructed outdoor area free of interference. Without satellites, the drone will not be able to position and become susceptible to drifting. However, with forward and downward vision sensors, the Mavic can hover precisely indoors or in places without GPS.
Stay flying longer
The Mavic is only 1/6th the size of the Phantom 4 but this reduction in size doesn't mean a reduction in flight time. The Mavic actually flies much longer than you would expect from its compact size. It is capable of reaching an absolute maximum flight time of 27 minutes and a maximum distance of 8mi (13km) due to its powerful, high-efficiency motors.
4K Ultra HD Video
Mavic supports 4K video at 30fps. No Electronic Image Stabilization is used, ensuring all footage is 4K. We have created a miniaturized, ultra-precise 3-axis gimbal for the Mavic, capable of stabilizing the camera even during high-speed motion for smooth video and sharp photos.
Photos with altitude
Everyone loves a good photo. Whether you just want to take a snap or are building up your portfolio, the Mavic’s 12-megapixel camera with Adobe DNG RAW support is ready to shoot.
DJI Mavic Pro - quadcopter
Quadcopter
Category
Vehicles - drones
Compatibility
iPhone, iPad, Android phone
Camera
Included - 12.71 Megapixel
Max Speed
65 kilometers per hour
Wi-Fi
734 g
Quadcopter
Category
Vehicles - drones
Compatibility
Remote Control
Yes - 2.4 GHz - max operating distance: 7 km
Power Source
Max Speed
Card Reader
microSD up to 64 GB
Micro-USB cable, power cable, charger, remote controller, 16 GB MicroSD card, gimbal clamp, intelligent flight battery, gimbal cover, 3 propeller pairs, Lightning to micro-USB cable, 2 RC cable sliders, obstacle avoidance system
RC Vehicle
Max Vertical Velocity
5 metres per second
Max Horizontal Velocity
17.8 metres per second
Wi-Fi
Gimbal
Control Angle Range
-90 to 30°
Digital Camera
Sensor Resolution
12.71 Megapixel
Capture Formats
MPEG-4, H.264, MP4, MOV
Video Recorder Resolutions
1280 x 720 (720p), 1920 x 1080 (1080p), 3840 x 2160 (2160p), 4096 x 2160, 2704 x 1520 (1520p)
Frame Rate
24 frames per second
Still Image Formats
JPEG, DNG
Max View Angle
78.8 degree(s)
Rechargeable Battery
Rechargeable
Supported Battery Configurations
3S
Lithium polymer
Voltage
11.4 V
3830 mAh
Run Time
Up to 27 min
734 g
Choking Hazard Warnings
Dimensions & Weight Details
With gimbal cover - 743 g , Folded - 8.3 cm x 19.8 cm x 8.3 cm x 734 g
