Mavic Air 2 takes power and portability to another level, offering advanced features in a compact form factor. Intelligent shooting functions and excellent image quality put aerial masterpieces within reach. Safer, smarter flight enables you to up your game while fully enjoying the creative process.
- DJI Mavic Air 2 Fly More Combo - drone
- Product Type
- Drone
- Included Items
- Battery charger, power cable, remote controller, battery to power bank adapter, shoulder bag, battery charging hub, RC cable (Lightning connector), RC cable (USB-C connector), RC cable (micro-USB connector), gimbal protector, pair of spare control sticks, 3 intelligent flight batteries, USB-A to USB-C cable, ND filter set (16/64/256), 6 pairs of low-noise propellers
- Category
- Vehicles - drones
- Camera
- Included - 48 Megapixel
- Max Speed
- 68.4 kilometers per hour
- Navigation
- GPS/GLONASS receiver
- Grey
- 25.3 cm
- 18.3 cm
- 7.7 cm
- 570 g
- Product Type
- Drone
- Included Items
- Category
- Vehicles - drones
- Size
- 302 mm
- Remote Control
- Yes - 5.8 GHz - max operating distance: 10 km
- Power Source
- Battery
- Max Speed
- Supported Flash Memory Cards
- microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card up to 256 GB
- Obstacle avoidance system
RC Vehicle
- Flash Memory
- 8 GB
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.1 metres
- Max Angular Velocity
- 250° per second
- Max Tilt Angle
- 35°
- Max Ascent Speed
- 4 metres per second
- Max Descent Speed
- 5 metres per second
- Max Wind Speed Resistance
- 10.5 metres per second
- Navigation
Digital Camera
- Sensor Resolution
- 48 Megapixel
- Capture Formats
- H.265, MOV (MPEG-4 AVC/H.264), MP4 (MPEG-4 AVC/H.264)
- Video Recorder Resolutions
- 1920 x 1080 (1080p), 3840 x 2160 (2160p), 2688 x 1512
- Frame Rate
- 60 frames per second
- Still Image Formats
- JPEG, RAW, DNG
- Still Image Resolutions
- 8000 x 6000
- Max View Angle
- 84 degree(s)
- Rechargeable Battery
- Rechargeable
- Supported Battery Configurations
- 3S
- Technology
- Lithium polymer
- Voltage
- 11.55 V
- Capacity
- 3500 mAh
- Run Time
- Up to 34 min
- Grey
- Localisation
- United Kingdom
- Dimensions
- 18.3 cm x 25.3 cm x 7.7 cm
- 570 g
Choking Hazard Warnings
- Dimensions & Weight Details
- Folded - , Battery - 198 g
- 0 °C
- 40 °C
